How to disable cruise control to prevent fire?
yxjin
06-17-2005, 02:15 PM
Ford is not going to recall Windstar even it uses the same switch as recalled F-series. How can I disconnect the switch myself, so that no current will go into the switch? Dealer can do it but charge over $50 for 10 minutes of work!
Thanks.
Jin
DRW1000
06-17-2005, 07:31 PM
I don't know the history of the fires you speak of but I would bet that pulling the cruise fuse or disconnecting the connector to the cruise module would be the way to go.
djp4059
06-19-2005, 10:49 PM
The brake pressure switch that is the cause of the fires , is located on the brake master cylinder, you can just disconnect the electrical plug that connects to it.
