oil change 1997 328i
johns97328i
06-17-2005, 10:11 AM
I got this car, my first BMW, last year and it's the first time I'm changing the oil. I haven't looked under the hood much. Where is the oil filter and how is the best way to get access to it? Is the oil filter a dealer part or can I pick one up at the local auto parts store. Thank you.
Cornelius
09-27-2005, 02:16 AM
The oil filter is under the hood a little to the right. it has a 1 inch to 1 1/4 inch top on it for a wrench, but be carefull because the entire oil filter housing is plastic. Just unscrew the top and out comes the filter. You can buy the filter at meijer, autozone, etc.
soapsuds22
09-28-2005, 01:13 PM
I used Mobil 1 synthetic in my 3 series. I would suggest that if you are going to put alot of miles on the car between oil changes Mobil one synthetic is a great choice of oil.
Antiburn
09-28-2005, 07:39 PM
The oil filter is right infront of the intake manafold. Its a 13mm bolt that holts down the lid. Replace all the washers and o-ring that you get with the filter. Your drain plug im sure you know where they are, its a 17mm. Your engine takes 7 quarts of castrol synthetic 15w30 (thats what dealers use) And to reset your oil light theres other threads in this forum that give you a how-to, Do a search
