A/C Draingpb13 06-16-2005, 02:46 PM My 1996 Nissan pickup is leaking water into the passenger side floor. The water is coming from a clogged A/C condensation drain. Anybody know how to fix this properly. I took it by a shop and they blew air through the drain. That worked for one day. How do I access the drain pan and clean it out? Thanks paul89se 06-16-2005, 03:01 PM Try taking out the glove box and lower panel. Then run the AC and see where exactly the water is coming from. gpb13 06-16-2005, 04:46 PM Try taking out the glove box and lower panel. Then run the AC and see where exactly the water is coming from. Thanks, that's sort of what I thought. I'll do that, Just as soon as i can bust that $$#% stripped screw off of there. I pulled the panel off @ 5 years ago and reached in there and pulled out a bunch of pine needles and seemed to fix it. I was wondering if the is a "technical" way to go about it. OffroadX 06-16-2005, 08:38 PM Run a coathanger up the drain hose that comes out at the rear of the passenger-side wheel opening bottom of the firewall. Automotive Network, Inc., Copyright ©2012
