Air blows through different vents.
nsheaffer
06-15-2005, 09:53 AM
Hello, When I have the AC on it normally blows through the panel vents. When I step on the gas it blows through the defrost vents. Can anybody help me with what is wrong? Also the air is not cold, I had the evaporator changed and recharged.
Thank-you
pissedriteoff
06-15-2005, 08:24 PM
you have to attach a check valve in the system. when ever you accelerate or increase engine revs the air switches to defrost. go to chrysler dealership and ask for check valve 24-001-036 or dcc#04677204 and have them install it. It takes 30 seconds to do. Have them reference tsb 24-01-96...it cost me 10.90cdn. if you want to put it in yourself i can email you a pic
idspud26
06-21-2005, 05:45 PM
I had the same problem on my 96 and it was a vacuum leak in one of the lines and a valve.
TurboSW
06-22-2005, 01:01 AM
I bet you have a cracked vac hose that leads to the cruse control servo that is under the battery. Replace that with some rubber hose from autozone and you should be fine. Save the old connectors from the old plastic hose. You will need them to use the new rubber hose.
tnduke
06-28-2005, 09:41 PM
I have kinda the same problem but when I accelerate up a grade the air quits blowing. It has been that way since I bought the truck. The cruise quit working about 8 months ago so do you think it could be the line to the servo went from a small leak to a large one?
TurboSW
06-29-2005, 12:40 AM
Could be. My AC was doing the same thing and the cruise stopped as well. I replaced the cracker vac hose. Replacing the hose fixed the AC, but it turns out that the cruise servo is bad. I haven't replaced it because I never really use it anyways.
seamedoo
08-13-2005, 11:00 AM
I have had the same problem as the previous individual. If you can still email the pic for installing the check valve, I would like that.
Thanks,
Seamedoo.
TurboSW
08-13-2005, 06:27 PM
You don't have to attach a check valve in the system. All you have to do is visually check your vac lines. It's probably the hard plastic hose that leads to the servo under the battery.
lolrus
08-29-2005, 01:50 PM
Hi i have the same problem i changed the line that goes to the cruise servo as it looked to be the problem cause of battery acid, Didnt fix it and other lines look fine, should i change the valve out or are there any other suggestions.
