batt side terminal thread size?hunter01 06-14-2005, 01:18 PM Can anyone tell me the correct thread size for the bolts that connect to the side terminals of a battery? I've tried 3/8 x 16 but it seems loose. s10blazerman4x4 06-14-2005, 01:21 PM I use an 8mm socket or wrench to loosen up the bolt that connects cable to terminal.Its a little nut and its a little tight in my 91 space wise but it works fine. hunter01 06-14-2005, 01:49 PM Thanks for the reply, but I'm looking for the thread size. s10blazerman4x4 06-14-2005, 02:01 PM my bad went to work for 815this morning only 4 hours of sleep still up sorry again coryhawkins 06-15-2005, 01:25 AM I always just use "OEM bolts" from Wal-mart or Advance Auto Parts to replace any rusted side-terminal bolts (like two bucks for two of them). hunter01 06-15-2005, 02:43 AM The reason I'm changing them is because I'm adding extra wires with lug connectors directly to the battery and I'm running out of thread to go into the battery. I found some extra long battery bolts at auto zone, but these are too long. I would just cut them but they aren't threaded all the way. I tried threading them the rest of the way with a 3/8X16 die but the're slightly thinner in diameter on the smooth part and there isn't enough meat on them to get a good thread. I may try to use a regular bolt that's just the right length so it doesn't bottom out, with a couple of washers and see if I get a good connection. Thanks for the reply. muzzy1maniac 06-15-2005, 04:05 PM Most hardware stores have thread "cards" in the bolt isle. It has all diff sizes of nuts and bolts imbedded in the card w/their sizes - you thread your bolt into the nut it fits a viola - now you know what the size is. Very handy. If not you can always add a few washers. Automotive Network, Inc., Copyright ©2012
