Traction Controljimtkirk 06-13-2005, 07:50 PM Has anyone had any problems with their traction control activating after you come to a stop and then start moving again? Mine used to work properly when there was gravel or ice or water. Now it will do it multiple times a day when the roads are dry and clean. Does anyone have any suggestions? By the way, it is a 2000 LT with the occasional hard shifting transmission. Thanks, Matt ss#4 12-02-2005, 01:29 PM Most likely it is a problem with one of the front hubs that contain the wheel speed sensor. I had a similar problem with the ABS on a Tahoe. Traction control function exactly the same just the opposite trigger. Accel vs decel Automotive Network, Inc., Copyright ©2012
