2000 GP Preventative MaintenanceUnlearned 06-13-2005, 11:49 AM Looking for some advice for a 60,000 mile Grand Prix: what sort of preventative maintenance is recommended now, versus what can wait? Some recommendations from a dealer (costing over $600 for all of them): - Rotate tires - Inspect disc brake system, rear brakes, PCV valve, PVC filter, emission system, spark plugs, wires & connectors, fuel tank cap & lines, drive belts, hoses, cables, lights, filters - Flush coolant & clean system - Lubricate & inspect front suspension, drive line, steering, hinges - Clean & re-pack non-drive wheet bearings - Check engine timing Just trying to understand what the best way to take care of my car is. Thanks jimmytroanoke 06-13-2005, 12:57 PM Looking for some advice for a 60,000 mile Grand Prix: what sort of preventative maintenance is recommended now, versus what can wait? Some recommendations from a dealer (costing over $600 for all of them): - Rotate tires - Inspect disc brake system, rear brakes, PCV valve, PVC filter, emission system, spark plugs, wires & connectors, fuel tank cap & lines, drive belts, hoses, cables, lights, filters - Flush coolant & clean system - Lubricate & inspect front suspension, drive line, steering, hinges - Clean & re-pack non-drive wheet bearings - Check engine timing Just trying to understand what the best way to take care of my car is. Thanks Looks like a hell of a lot of "inspections" for 600 clams. The only work being done is the coolant flush/fill, tire rotate, and bearing repack. For that kind of money, all fluids and filters should be changed as well as belts and hoses. All these inspections are is an opportunity to upsell. Out of that 600, allow 20 for the antifreeze. The rest is labor. At 75 per hour that leaves 7.7 hours labor for what a competent tech can do in 1-1/2 hours, 2 tops. Try another dealer or an independent shop. You can do better. But stay away from quick lube places or muffler shops. They arent qualified to inspect anything. Just my :2cents: kustomkid54 06-13-2005, 10:43 PM Looking for some advice for a 60,000 mile Grand Prix: what sort of preventative maintenance is recommended now, versus what can wait? Some recommendations from a dealer (costing over $600 for all of them): - Rotate tires - Inspect disc brake system, rear brakes, PCV valve, PVC filter, emission system, spark plugs, wires & connectors, fuel tank cap & lines, drive belts, hoses, cables, lights, filters - Flush coolant & clean system - Lubricate & inspect front suspension, drive line, steering, hinges - Clean & re-pack non-drive wheet bearings - Check engine timing Just trying to understand what the best way to take care of my car is. Thanks OK, lets start with the year and is it a GT or a GTP? The 60,000 miles, Highway? Every little bit helps. Thanks Unlearned 06-14-2005, 09:41 AM OK, lets start with the year and is it a GT or a GTP? The 60,000 miles, Highway? Every little bit helps. Thanks It's a 2000 Grand Prix GT. About 2/3 of the miles are highway.... thanks GTP Dad 06-14-2005, 10:23 AM Practically everything the dealer wants to inspect are visual inspections and can be done in about 30 minutes by anyone that knows anything about cars. I think the dealer may be a little agressive in his pricing as I am certain that parts are extra! If you need new brake pads or rotors the price will go up. Wires and plugs are easy and can be changed with a sparkplug wrench and a plug gapping tool. The belts should be changed if they have never been changed and the PCV and filter cost about $5 at a parts store and are easy to replace. Flushing the cooling system will cost $75. Other filters such as the fuel filter should be changed and lubing the chassis is a good idea as well. I think you need to go to another shop and get another quote. There are a lot of places that will do brake inspections for free. I hope this helps you make you decision. As you can tell I don't care for dealers!!! kustomkid54 06-14-2005, 10:32 AM It's a 2000 Grand Prix GT. About 2/3 of the miles are highway.... thanks Sorry about that. I should have seen your header. Or get new glasses. I would listen to Dad. The dealer is a place where you buy cars. But they make most of their money doing stuff on your car that you either don't need or you can do yourself. :uhoh: Good luck Automotive Network, Inc., Copyright ©2012
