Replacing the vcr with dvd player on a chevy venture 2001ikontech 06-13-2005, 10:37 AM I'm having a problem removing the front panel on the venture 2001 removed most of the screws but couldn't get the bottom part off. Are there any other screws that are hidden that I should know about? Thanks in advance GregA 06-13-2005, 10:53 PM I'm having a problem removing the front panel on the venture 2001 removed most of the screws but couldn't get the bottom part off. Are there any other screws that are hidden that I should know about? Thanks in advance I think you are stuck on the same screws I had a problem with. If you take the LOWER part of the console loose and slide it out of the way, you should be able to access TWO screws that go straight up near the cup holder - if you have one. You will have to slide the cup holder out to see them. To get the lower console out of the way WITHOUT cutting any wires to the 12V DC sockets, you will have to separate the back plastic panels from the front part. There are 4 plastic tabs that will need to be carefully pushed (with a flat screw driver) to separate the pieces. See the link below for where to find them. Lower Console Tabs (http://www.links-to-golf.com/van/lower-console-tabs.html) I hope this helps. Please let me know. Take Care, Automotive Network, Inc., Copyright ©2012
