Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 06-13-2005, 12:00 AM   #1
robzone0911
robzone0911 Normal reputation
Question I Need Help Bleeding My Cooling System!
I recently fixed my coolant temperature sensor and radiator fan on my 94 Z24 3.1L...but it still overheats (it just takes longer). I believe there is an air pocket in the system somewhere, and I would like some ideas on the most effective way to bleed the system. I haven't checked my thermostat yet, but I will replace it while I am bleeding the system. Also a recommendation on a good thermostat would be appreciated. Thanks in advance...Robert
1...2...3...go! 16.3@85mph 2001 Cavalier Z24 Happily traded for my Z32
robzone0911 is offline   Reply With Quote
Old 06-15-2005, 11:40 PM   #2
deadBird
deadBird's Avatar
deadBird Normal reputation
Re: How do I bleed the cooling system?
Not sure about a 94, but look for bleeder screws around the t-stat and hoses. It's a good idea to let the engine warm-up (so t-stat opens up) and grab a thick rag to cover it up while you open it, else you may burn yourself. BTW, don't tighten them down much, they're brass.
deadBird is offline   Reply With Quote
Old 06-16-2005, 05:45 AM   #3
OverAllComa
OverAllComa Normal reputation
Send a message via AIM to OverAllComa
I just let the car warm upwith the coolant resevoir cap off.
The air bubbles tended to work themselves out over time, anyways. The top of the resevoir is usually the highest part of the entire coolant system so all the air tries to go there. All you should need to do is drive around for a day, check and fill the coolant, repeat for a week.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
OverAllComa is offline   Reply With Quote
Old 06-17-2005, 01:30 AM   #4
robzone0911
Re: Re: How do I bleed the cooling system?
Thanks for the help...
Bookmarks
Google
Web AF
