Converting A/C to R-134a?SteveK2003 06-12-2005, 10:52 PM My brother has a 1993 SW2 wagon and wants to convert his A/C over to R-134a. He has the kit but doesn't know how to discharge the system of the old R-12. Any other helpful advice I can give him? sierrap615 06-13-2005, 01:07 AM the vehicle needs to be taken to a EPA 609 certified tech to be discharged and evacuated, special equiptment and training is needed. i also suggest having the tech retrofit and charge the system. the tech will then be able fully service the system if any other modifications are needed for the retrofit(IE - oil, seals, hoses) to prevent any problems later, as well as accuritly charge the system(the suggested way also requires special equiptment). oldmanwalking 06-27-2005, 08:58 AM My brother has a 1993 SW2 wagon and wants to convert his A/C over to R-134a. He has the kit but doesn't know how to discharge the system of the old R-12. Any other helpful advice I can give him? I agree with above..take it to a tech. The tech will pump out the r-12 into a certified container. Then he should change the accumaltor and fitting. The fittings are not the same for r134. Then he wil pump the system down to a vacumm to totally dry it out and then add oil and new freon 134. Just keep in mind that a converted r134 system will not cool as good as the newer 134 factory systems.. but that is ok for it's like an ice box anyway in a saturn. Automotive Network, Inc., Copyright ©2012
