Re: help with these CEL codes
Find the pinout for the maf plug, and see if the ground pin is grounded. I have no idea if it is supposed to be or not, but might as well check. Look for a pin that got pushed out of the connector, broken wire, etc. Also ohm out the wires from the pin at the connector, to the pin at the ECU. The vfaq has a pinout for the ECU end, for the maf end try the vfaq or instructions for the 2g mas conversion in a 1g.
An inline motor only has one bank of cylinders, so every code will be bank one. In this case, the fuel trims in the ECU are maxed out. If you are on stock injectors this is usually a dead O2 sensor. But I have to wonder if the MAF issue isnt causing this too. I'd have to think about that more.
Kevin Jewer
POS RWD - 8.9 at 156, 1.20
POS Mightymax, 4g63/TH350 - TBD
www.POSracing.net
