safc1 tuning on a pte 50 trim
scottsee
06-12-2005, 02:38 PM
im trying the help out a guy in town car get his car dialed in, he bought the car allready modified. he has a pocket logger that sucks ass. you cant log runs and review them from the pda, you have to dock it to a computer, so i tryed to read RPM, front o2 & timming off the logger while he made 10-15 2nd and 3rd gear pulls, but to no use. we set his safc from on high/low anywhere from -20% to -12% (he kept telling me to zero it out, i just told him to shut up and drive). I couldn't get rid of his fuel cut around 6000 in 2nd. so i was hoping someone could give me a good base line on the SAFC1 for high/low's
the car isa 97 gsx manual with:
PTE 50 Trim
HKS 40mm External Wastegate Vented to Atmosphere
HRC 3 inch Eliminator Downpipe
HRC upper intercooler pipes with HKS Super Sequential BOV with recirculation pipe
SPEARCO 31.25x9.25x3.5 inch with 2.5 Pipings
HKS 3 inch Super Dragger Full Catback
3 inch Test Pipe
NGK BPR7ES Spark Plugs
Magnecore Performance Spark Plug Wires
3 Inch Intake Pipe
Fipk filter
INJEN Fuse Box Cover (Polished)
DENSO 660cc Injectors
Walbro 190lph Rewired fuel pump
2G Exhaust Manifold Ported Matched for Turbo Inlet
HKS EVC EZ Boost Controller
HKS Turbo Timer
APEXI Super Air Flow Converter fuel controller
ACT 2600lb Xtreme Clutch Kit
ProStree Flywheel
3 Gauge Full Replacement Pillar with
AUTOMETER Boost Phantom Gauge,
AUTOMETER Air Fuel Phantom Gauge,
AUTOMETER Egt Phantom Gauge
TEAM RIP ENGINEERING EGT PROBE
Eprom 95 Ecu w/ Stage 3 KeyDiver Chip
POCKETLOGGER Software/Program
PALM PILOT to operate software and tune car
scottsee
06-12-2005, 06:06 PM
the car needs alot of help, its slow as shit. his timming droped down into 8-9 range in the higher rpms right before, durring fuel cut. i set his boost to 15psi. i forgot to mention that.
1g90gsx
06-12-2005, 06:19 PM
dam scottsee i wish i could help you but i dont know to much about the afc settings.i need to get up to speed on it but the maft i know pretty dam good.let me look around and see what i can find for ya!
scottsee
06-12-2005, 09:12 PM
i figure a good place to start is around -30% on high/low. and go from there. what do you think?
kjewer1
06-13-2005, 12:37 AM
450/660 - 1 is about -32%. That will compensate for the injectors, and that is where you should start. That should provide stock 9.5:1 AFR, but timing could be high if you are not staying over 2.1 g/rev airflow. If by zeroed out you mean he wanted to run at 0s, it would be 32% too rich. I'd be surprised if the motor even ran halfway decent.
scottsee
06-13-2005, 01:30 AM
thats why i told him to shut up! im going back over to his house on tuesday to fix his TPS it shows 92% at wot, he also seems to think there is a boost leak. i'll get some logs on a 3rd gear with -32% high and -32% logging Rpm, front 02, timing.
kjewer1
06-13-2005, 02:41 AM
The ECU considers anything over 90% to be WOT anyway. Set the TPS so that its jsut barely on zero (almost on 1) percent with the throttle closed so the idle switch functions properly. Then see what you get on the high end. Some poeple make the mistake of going to far negative (still shows 0) reducing the reading at WOT. Either way though, the ECU will still function the same over 90%.
A boost leak will make it even richer than it would otherwise be, so I would definitely let him take care of that shit before doing any more tuning.
Good luck with it.
spyderturbo007
06-13-2005, 08:33 AM
Is this the software from www.pocketlogger.com If so, you can read the logs on the PDA. After you create a log, click on the bottom right side of the screen. It looks like a magnifying glass. This will take you to the saved log screen. Then just click on any log to bring up the graphs. You can then drag your stylus around to see the #'s. It's a little clumsy at first, but better than going through all of the shit with the computer and PLViewer.
If it's not the software from www.pocketlogger.com , than nevermind! :smile:
