high rpms!!!!
mindtwizzter
06-12-2005, 12:32 PM
i have 96 eagle talon esi 5spd..... ok when i crank my car in the morn the car idles at 800 but after driving the car around for a while and i come to a stop light the idle sticks around 2k and slowly comes down to abot 1200 and stays there this problem just suddenly happened,i checked my throttle cable and its fine i shecked the tps sensor it is fine anyone have any suggestions on what it could be,help is appreciated..thanks
l_eclipse_l
06-12-2005, 01:00 PM
It could be that when you are in gear, the car will idle slightly higher than if you were in neutral and just sitting there. 1200 rpm is not all that bad if you are sitting at a light. Just be happy it's not doing the opposite and idling lower than 700 or 800 rpm....
Turbodog97
06-12-2005, 05:32 PM
mine does the same, you check that idle screw? In the morning mine is about 900 and after it heats up it gets and stays around 1100-1200. I think its just when the idle screw heats up it moves around and "adjusts itself" correct me if Im wrong. Also when the fan goes on and off your rpms should vary up and down 500-600 unless you dont have AC like me :crying:
coolguycooz
06-13-2005, 04:19 AM
also could be your cold air idle thingy when its cold it should idle higher and once your car warms up the coolant melts the thing and it should drop. but in your case it might be messed up just a thought. check the cold air idle sensor thing forgot what its called exacly.
Nstyle29
06-13-2005, 11:59 AM
mine will run below 7-800 rpm at idle, what does that do?
l_eclipse_l
06-13-2005, 12:34 PM
How much lower does it idle? Cars may struggle to run when the idle is not at a minimum level. If you don't notice anything unusual and it has always done that, your probably fine. If it all of a sudden started to idle lower than usual for a period of time, there could be a multitude of things to check for. Spark plugs, injectors, etc.
coolguycooz
06-13-2005, 12:35 PM
when its warm that sounds like where it should be at.
Whathits14
06-13-2005, 03:07 PM
Car should idle 700-800rpms. Anything much higher is not normal. It would be more common too see slightly high rpsm when your first turn on the engine, than after it has been on.
mindtwizzter
06-13-2005, 05:40 PM
would it have anything to do with me taking out my o2 sensor from my header cause i do have a check engine light on ever since i took it out just never put it back in since i got my after market header
Turbodog97
06-13-2005, 06:29 PM
okay taking out your primary o2 sensor(the one on the header) will make your car run in "safe-mode" basically. You need that sensor in there because it's what decides your air/fuel ration without it your car is going to suck in performance and going to be running rich 24/7 which you don't want to do forever. Put it back in!!!! lol and see if it remedies this
l_eclipse_l
06-14-2005, 07:59 PM
Would have been good to know, makes it easy to diagnose
mindtwizzter
06-15-2005, 05:29 PM
k thanks guys i got the prob fixed it was the sensor
ty all for your help
