How to install remote starter & alarm for 97 venture ?
chuasam
06-11-2005, 03:42 AM
I just bought a remote starter & alarm ( 2way ), i need wiring diagram for my chevrolet venture 97 ,where should i look for it , ign1, ign2, door input trigger... Thank you for allhelp.
ponchonutty
06-12-2005, 11:45 AM
www.bulldogsecurity.com
double check these wires before connecting. Sometimes they are wrong.
chuasam
06-15-2005, 02:00 PM
thank Ponchonutty.
1. idid insll it , but it not work , i think it could be the second ignition wire ( the schematic they gave me required the 2nd ign wire to start up the car, but my remote starter had only 1 input for ign1 , even i try connect the 2 ign wire 1, 2 to ign at my starter module ) still not working.
2. i am confuse a bit at a key side for remote starter. Usually , on the key side when we rotate they have 5 positions ( acc1, key off, acc2 , run ,crank ) , but for 97 chevrolet venture ( acc , off , run , bulbtest , crank )
any idea , please help me .
i had installed previous 6 remote starter , alarm with no problem.
ponchonutty
06-15-2005, 08:50 PM
Well, you should have seen a red and a red/white wires. I usually split my power between these. My remote starters usually have 2 heavy gauge inputs though. You should have found the yellow starter. The pink and white wires might be your problem. BOTH wires need to see 12v. constant in order for it to start. If you RS only has one output, you can cheat by hooking your one ign. output to BOTH of these wires. The correct way is to use a relay. You should have an ign. 2 output which is (neg). You'll use that to trigger the relay. Then, all you have left is the orange acc. wire.
If all that above is correct and you have good power and grounds, it might be something else like the saftey neutral switch or brake wire. Or, maybe the programming of the unit itself???
jhong1226
06-16-2005, 11:43 AM
if you have a PASS KEY you will need a module to disable that coz that will prevent you from starting the car w/o the key in the ignition.
chuasam
06-16-2005, 12:43 PM
how do i check if i have a pass key ( i m newbie ).you mean , a key with resistor inside .
No i can start with a metal key ( do not have plastic at the back )
ponchonutty
06-17-2005, 09:08 AM
no '97 Ventures had PK or VATS so that's not your problem.
