Manually advancing odometerPowerefx 06-10-2005, 09:28 PM Hey, i have a 95 escort speedomoter i swaped with my 93 escort. I need to advance the milage to make sure i have correct millage on the new odometer. Does anyone know how to quickly manually advance the milage?Thnx mr_tw 06-11-2005, 12:29 AM my friend has talked about doing this and said all that he had to do was get the cable that is attached to the odo and hooking it up to a drill, (allot simpler with the instument cluster uninstalled) but I myself have never personally done this and he did it on a mid 80's olds so you never can know for sure sixleggedinsect 06-15-2005, 07:31 PM my friend has talked about doing this and said all that he had to do was get the cable that is attached to the odo and hooking it up to a drill, (allot simpler with the instument cluster uninstalled) but I myself have never personally done this and he did it on a mid 80's olds so you never can know for sure for sure, pulling the cable, and putting it in a drill chuck would work. but does spinning the odo that fast cause problems? what is the rpm of the speedo cable inside its sheath? drills get very fast. if the normal rpms of the speedo cable is very slow compared to a drill, it might cause problems. if the normal speed of the cable is similar to a drill, you will be sitting there 'drilling' for a long long time. just thoughts. gbic1 06-22-2005, 11:22 PM If tyou are carfull you can flip the wheels witha pocket screwdriver. Automotive Network, Inc., Copyright ©2012
