No rear heat or a/c controlBedwardjohnson 06-09-2005, 01:46 PM Recently discovered the rear hear and a/c controls don't work. It also doesn't work when I use the front controls for the rear. There is not heat or a/c and the fan doesn't work either. I checked all the fuses related to the heat, a/c, and rear hvac. They are all good. Is there a relay that is not obvious or labaled? Any ideas what I should check next? gobbell1 07-21-2005, 09:29 AM Recently discovered the rear hear and a/c controls don't work. It also doesn't work when I use the front controls for the rear. There is not heat or a/c and the fan doesn't work either. I checked all the fuses related to the heat, a/c, and rear hvac. They are all good. Is there a relay that is not obvious or labaled? Any ideas what I should check next? I'm having the same issue to my 2001 yukon. Did you ever get yours resolved? If so, what was the fix? thx cg Automotive Network, Inc., Copyright ©2012
