Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 06-08-2005, 08:04 PM   #1
linkinparkfan311
linkinparkfan311 Normal reputation
Unhappy Cooling fan problem
hmm ok...well my cooling fan hasn't been working for awhile, and since the hot days are coming i need to get it fixed asap. Lately i've just been cooling down my engine with the air going through the radiator and to the engine. Just about a few weeks ago I replaced my water pump because it had broken, and just recently fixed one of my thermostats. I have checked all fuses and replaced my cooling fan relay. Any suggestions please!!! i can't go on with a overheating engine!!!!!
And one more thing. Today i was checking the wiring and stuff and i put everything back together and the cooling fan started working for one run. But after the engine cooled down for a few hours i had started it back up and let it get up to temp and the cooling fan didn't work. Let me know what i can do?...PLEASE!!!
linkinparkfan311 is offline   Reply With Quote
Old 06-08-2005, 10:18 PM   #2
OverAllComa
OverAllComa Normal reputation
Send a message via AIM to OverAllComa
Re: Cooling fan problem
I can't speak for everyone, but my fan doesn't kick on til it's a fair amount past normal operating temp. These motors are built with tolerances, it's not like they have to operate at one specific temperature. If that needle dips into the red, you're in trouble, but pushing 3/4 on the gauge is fine as the fan should kick in around then.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
OverAllComa is offline   Reply With Quote
Old 06-08-2005, 10:24 PM   #3
BorgKing
BorgKing's Avatar
BorgKing Normal reputation
Ditto. About 3/4 of the way to red mine kicks in (lots of data collection from having a ghetto air filter + stock intake combo ^^). Sorry I can't help you since I'm not that "motor-savy". For now, I guess just blow out hot air when you're in bumper to bumper rushhour traffic (or turn on the AC if your car's like mine... I still don't understand how turning on the AC turns on the cooling fans? Is that some GM specific design? I sure don't see it anywhere else).
BorgKing is offline   Reply With Quote
Old 06-08-2005, 10:45 PM   #4
i3o2Matt
i3o2Matt's Avatar
i3o2Matt Normal reputation
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
you could always wire the fan so its operated manually by flickin a switch on or off...that's also an idea...
i3o2Matt is offline   Reply With Quote
Old 06-10-2005, 06:56 PM   #5
linkinparkfan311
hmm well several times in traffic it gets pretty close to the red line and sometimes it does. but since i usually drive in no traffic it usually doesn't get too hot since the air flow cools it down enough. hmm if you have any more input on this i would be greatly appreciated. thanks for the replies that are already given
Old 06-10-2005, 07:08 PM   #6
big dude1
big dude1 Normal reputation
this is about the dumbest conversation ive seen... it rivals the ones involving the removal of governors
i love my new sound system... Alpine type R 12" sub, Alpine deck, and MTX amp
2001 Z24 cavi, and it owns
big dude1 is offline   Reply With Quote
Old 06-10-2005, 07:30 PM   #7
OverAllComa
Don't be a smart-ass. This is legit, these guys didn't know that there are clear tolerances for operating temperatures. No shame in that.
On an amusing not, if the heat scares you that much, turn on the AC. It'll make the fan come on.
Old 06-10-2005, 08:25 PM   #8
big dude1
i know its legit... but its still funny
Old 06-12-2005, 11:53 AM   #9
chevyguy93
chevyguy93 Normal reputation
Hmm. sounds like quite the pickle =P
What i would do, is when your fan Should be turned on, take a test light and check to see if the fans getting voltage. If it is, then its a simple matter of the fan starting to die, thus get a new one. If not, hardwire it directly to the battery with a switch inside your car for easy turn on/off.
chevyguy93 is offline   Reply With Quote
Old 06-15-2005, 11:37 PM   #10
deadBird
deadBird's Avatar
deadBird Normal reputation
If the A/C doesn't make the fan come on, then try replacing the relay. But first, hard-wire the fan to make sure it works at all.
deadBird is offline   Reply With Quote
Bookmarks
Google
Web AF
