ZC & a T3/T4 Turbo, Whats safe psi?
digil
06-07-2005, 11:58 PM
Sup all. I got a 92 civic, with a zc single cam motor in it. SOHC
Now, i want to turbo it, wanna run about 10 psi maybe 12 MAX. What should i do to run that safely?
Some people tell me the block will handle it easily, and some say i should really get rods and pistons, and well a new head gasket.
That true? Or should i be fine on stock internals for 10 psi?
Http://www.cardomain.com/id/lazyme
That's my ride. I know going b16a2 and turbo is the best thing. But dont really wanna spend 2000$ on a motor w/ install. Kinda wanna work with what i got.
Thanks for the help...
CivicSpoon
06-08-2005, 01:52 AM
Do a compression check first, make sure your engine is worth turboing.
Next, it's all about tuning. If you want quite a bit of power, you HAVE to tune it. If you can't or don't want to spend the $ to get a good engine managment system and get it professionally tuned; then you might as well take your $ out of your wallet and set it on fire. Honestly, you'll blow your engine if you boost that much without a great tune. and good EMS. But I'd recommend checking out www.turbod16.com (http://www.turbod16.com) Search the forum for all the info you'll need, and do it before you start asking questions over there (they'll rip you a new one for being lazy and not searching).
Whathits14
06-11-2005, 10:30 PM
You will need more than just a tune to boost 10psi. Look closer to boosting 7-8psi with a great tune. You are going to have to worry about your rods, detonation etc before you boost 10psi.
CivicSpoon
06-11-2005, 10:53 PM
Check out turbod16.com
scottsee
06-12-2005, 05:16 AM
tune my left fucking nut. shit, his question is how much boost can he run!! you need to stay under 25lb/min airflow on your stock internals. i would'nt run more then 15lb/min personaly. so turbo sellection is the most important. you can do it the wrong way, or the right way. if you make a goal and stick with it, your golden. if you switch around alot like a kid on sugar, you will spend alot of $$$.
the reasion im saying this is becasue every turbo flows diffrent at diffrent psi. selection is key. "everything" else comes after that.
