4afe to 4af(z)e *PICS!!!!* (not 56k friendly)
91 Celica St
06-07-2005, 08:12 PM
okay well i finally decidied on a swap and went and bought myselfa 4agze, tore it araprt and blah blah blah ....im goin all motor for now on this bad boy, hoping to break 180WHP n/a...but this motor is being built for turbo so when i actually get a turbo kit im hoping for about 300WHP
as of now its comptelty just torn apart....ere are some pics
http://files.automotiveforums.com/gallery/watermark.php?file=/500/157859supervalve-med.JPG
http://files.automotiveforums.com/gallery/watermark.php?file=/500/157859bigport1-med.JPG
^bigport head, not being used :)
http://files.automotiveforums.com/gallery/watermark.php?file=/500/157859head1-med.JPG
^this head was a fucking bitch to get off, took me like 30 minuts to get it off cuz one of the head studs was stripped as fuck
http://files.automotiveforums.com/gallery/watermark.php?file=/500/157859grinding-med.JPG
ginding....;)
http://files.automotiveforums.com/gallery/watermark.php?file=/500/157859crank1-med.JPG
^notice nijers head pokin out through the bottem of the motor...lol
http://files.automotiveforums.com/gallery/watermark.php?file=/500/157859oldpis-med.JPG
old pistons wrings were toast and there was some rust on #3 and #4 pistons...not good
http://files.automotiveforums.com/gallery/watermark.php?file=/500/157859pisrods-med.JPG
im reuing these rods but im going to have them matched and cut so their under 400 grams.... i feel like revving to 10 K :)
http://files.automotiveforums.com/gallery/watermark.php?file=/500/157859parts-med.JPG
mmm parts, notcie the 256 duration cams as opposed to my 240 duration stock ones?
http://files.automotiveforums.com/gallery/watermark.php?file=/500/157859newblock-med.JPG
this is how it looks chilln in my garage right now
so far this swap is
4agze bottem end
forged rods
10.3:1 comp pistons w a 2mm head gasket for a 9.3:1 comp
port/polish on intake and exhuast side
3 angle valve job
256 duration cams
gze 365cc injectors
smt-6 pigyback ecu
so yea im just hoping to break 180 Hp but ill prob go into the 200 range, hoping to break 13's by end of summer
tell me what u guys think
SigmaProjects
06-08-2005, 06:33 PM
you are the man, you seem so comfortable with tearing apart the motor, major props. Man you are making me jealous, still looking for my car...
Vip09
06-09-2005, 03:57 PM
Good luck man.. hope everything goes smooth. One question though.. why not go with the GZE head.. GE means high flow head which would be critical in a high revving NA engine.
91 Celica St
06-09-2005, 04:21 PM
thanks guys, theres many a reasons why im goin with the F head but heres just a few
i mainly hate being like everyone else, hecne why i bought a celica, i didnt want to be like every other honda head out there with a hatch w a dz swap etc... everyone uses the Ghead and says the F head flows like crap and is just a big boat i dont belive that heres why
i look at the two heads as this, a two stoke motor and a 4 stroke, a g head has to stay in high rpm's to stay in powerband, and mostly has all up top shit, hence why they need to revv hgih to make power
i beleve i can keep the F head at under 8K and make more power than a G head, this is being used for mainly hill climbs and mountain passing, theres alot of Touge type racing out here so i need all the botem end i can get and an F head will produce that
second of all the G head flows pretty much sideways, no real angle to it, and the squish area of the head is actually VERY diffrernt than the F head, the F head flows at a relativly steep angle , granted stock they flow like crap but im getting ALOT of headwork done to it, and i belive this head has potnetial, but i do agree, stock it flows like crap but can be made to flow relativly well
also how many G head motors do you know that can put out more TQ than HP? slim to none, with this setup im looking at more Tq than i am hp witch is ideal for the type of racing i will be doing and yes this new motor i have now is going to revv to about 7K w/out the valves srpings and cam m going to use, afterwards proably about 8K but the f head will have a more broad tq and Hp band than just having all top end like a g head
and basically who woudlnt like to have a 200+Hp motor that gets 30 MPG :)
SigmaProjects
06-12-2005, 03:41 AM
do you know if those exhuast control valves work or not? The ones to creat some back pressure at low rpms and open up at higher rpms?
91 Celica St
06-12-2005, 04:41 AM
well its officially oficial, G head cams will DEFFINATLY not work on a f head
not jsut cuz u cant move around the slave gear setup, but the way the distributor is setup is diffrent on the 2 motors, not to mention most gze cams have DLI ignition anyway, so there goes that idea, i DEFINATLY need new cams for this thing, i wont make nearly as mcu h HP withough them
91 Celica St
06-25-2005, 06:52 PM
update again: block is getting machined, it was pitted and some rust in cyilendar #4 so it was bored .30 over, crank didnt need to be reground and all rods are getting balanced and shaved down to 500 Grams....the machinest said i should be able to revv to about 8 grand, mabe more with a new cam, im hoping to break 9 but i duno if thats gunna happen
blakscorpion21
06-26-2005, 12:00 AM
damm its like a broken record . good luck
SigmaProjects
06-26-2005, 04:34 AM
man 500 grams is so little, that's only about 1.1 lbs. =)
