Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 06-07-2005, 11:40 AM   #1
alphabetfamily
alphabetfamily Normal reputation
Question Bumping noise in rear 96 Grand Caravan SE
Hi all,
I have a 96 Grand caravan SE with 184K miles on it.
I recently replaced all the tires, the shocks and struts, along with various other parts, non suspension related.
The van has had a 'bumping' noise that almost sounds like a flat tire (increases at higher speeds, etc) for some time... I thought the new tires would correct the problem but it has not.
Since this vehicle is front wheel drive (but I'm fairly certain that the noise is coming from the rear) I'm at a loss for what to check.
Perhaps it's just a stupid question, but if anyone has experience with this and can suggest something or point me in a direction I'd greatly appreciate it!
alphabetfamily is offline   Reply With Quote
Old 06-09-2005, 11:32 PM   #2
sandokana
sandokana Normal reputation
Re: Bumping noise in rear 96 Grand Caravan SE
Did you check the rear wheel bearings?
sandokana is offline   Reply With Quote
Old 06-10-2005, 01:02 PM   #3
waltham41
waltham41 Normal reputation
Have you looked to see if your exhaust pipe is bumping against the body somewhere in the back and making this noise? I have a similar problem and that is what I suspect.
waltham41 is offline   Reply With Quote
Old 06-20-2005, 12:53 AM   #4
allen28
allen28 Normal reputation
what about you spare tire..is it tight?
allen28 is offline   Reply With Quote
Old 06-30-2005, 08:41 AM   #5
mieth
mieth Normal reputation
I had that same problem and it ended up being the wheel bearing. I think if you jack up the car, you'll probably find that the wheel has a lot of play in it. Then this means the wheel bearing is bad.
Good Luck!
mieth is offline   Reply With Quote
Bookmarks
Google
Web AF
