95 neon strutsfordnut61 06-05-2005, 03:42 PM How do I adjust the camber on the right side strut on a 95 neon? maykelcj 06-05-2005, 03:50 PM they do not adjust. You must get an adapter kit. tasattack 06-05-2005, 11:00 PM actually it can be done professionally, but you need camber plates to do it. bosleys tires in wichita ks adjusted all my camber on my car, did a great job at that and only that. after spending 700$ on what was supposed to be a complete suspension repair from a 3ft pothole, i got a 3ft shaft instead. however they can adjust the camber but its gotta be set on a machine and they use plates to do it. thats all i was told when they did mine. i guess the plates are similar to the use of shims... das2123 06-06-2005, 10:11 AM How do I adjust the camber on the right side strut on a 95 neon?You can't adjust them unless you have crash bolts. Mopar Camber Adjusting Bolt Package (front bolt p/n 4762135, about $20 for two) and torque them to 140 ft/lbs. DO NOT overtorque them. Remember you want negative camber, not positive, but only around -2 degrees. NJH_Habitatpro 07-02-2005, 07:41 PM Dude I adjusted mine you dont have much to adjust but if its off just a little bit then you can undo the bolts and move the strut a very little bit and that knocked mine back into place. Automotive Network, Inc., Copyright ©2012
