2001 e39 60000 mile Inspection IItimabe 06-05-2005, 11:55 AM What needs to be done to complete the Inspection II? Is there a checklist available? I'd rather do the job myself if it's possible. Thanks in advance. Antiburn 06-06-2005, 08:42 AM -oil -oil filter -spark plugs -air filter -cabin filter -washer fluid -rear dif fluid level check/ change if necessary -engine belt check -visual engine leak check -gas filter -brake inspection -complete interior check over (lights accessories ect) -complete exterior light check -tire wear check -bent rim check -clear/ repair fault codes -front ball joint check. -exaust mounting check -battery test read out -final test drive Theres a more complete list in the 3 series section I believe but thats pretty much the basics. timabe 06-07-2005, 12:32 AM Thanks very much! Automotive Network, Inc., Copyright ©2012
