Help needed...GMC-Titanic 07-15-2001, 10:42 PM Hi, I have a GMC Sierra 1992 and I would like to: 1) put DRL (Daytime Running Light) system, 2) make the head light to flash like the cops cars. My truck has a Single sealed beam headlight system. Thanx in advance for your posting. http://www.geocities.com/gmc_titanic DVSNCYNIKL 07-16-2001, 04:46 PM The DRL's you can get them from your local dealership. They should be able to install them on your truck and you get a discount on your insurance. As for the alternating light pattern things a.k.a. the cop lights. Those are illegal for you to use, but attainable. Just know that if a cop sees them on your truck, you're in a heep(no pun intended:D) of trouble. You can go here and look for them. Autotoys (http://store.autotoys.com/cgi-bin/wfp53024.storefront) GMC-Titanic 07-16-2001, 11:57 PM Thanx for your reply... First, I don't live in the USA... I just want to drive my truck with my lights on... I import most of all the accessories for my truck from the states, that's why I want to know where to buy the DRL system kit. And as for the a.k.a. "cops lights" it's just for off road and for shows. Regards, RiggsT 07-21-2002, 06:38 PM Some of the PD's and FD's get magazines that have items that make your lights like the cops do. As in the previous message these are illegal on non-emergency vehicles. You may obtain them and if you hook them up, I recommend that you do this on a temp basis. If you are caught you could have your vehicle impounded. chuxted 03-21-2004, 12:00 AM As far as a DRL system, check the aftermarket parts stores. A universal DRL system is available from Blue Streak Standard. The "cops lights" are also available from Grote. harrdave 03-29-2004, 05:25 PM The blinking lights you refer to are called "wig wags" and they can be made to make your headlights/brakelights wig wag, your blinker lights on all four coners wig wag or both. Probably the best place I found for these is at a place called Gall's. Visit www.galls.com and search for "wig wags". Hope this helps. GMC-Titanic 03-29-2004, 08:01 PM Hi guys, I found this great website: http://strobeguy.safeshopper.com and I need to buy the Headlight / Taillight Flashers. These flashers all feature different flash patterns and different applications: Flash 1: The FLASH-1 does a standard back and forth wig-wag type pattern at a rate of 1.9 flashes per second. Flash 2: The FLASH-2 Does 3 flashes per side simultaniously before going back and forth in a wig-wag type pattern, it then repeats both these patterns every 4 cycles. Flash 3: The FLASH-3 does a standard back and forth wig-wag type pattern at a rate of 3 flashes per second. Installation instructions for Flash 1, 2,& 3: http://www.strobe.com/pdfs/flash-install.pdf GMC-Titanic 03-29-2004, 08:01 PM Hi guys, I found this great website: http://strobeguy.safeshopper.com and I need to buy the Headlight / Taillight Flashers. These flashers all feature different flash patterns and different applications: Flash 1: The FLASH-1 does a standard back and forth wig-wag type pattern at a rate of 1.9 flashes per second. Flash 2: The FLASH-2 Does 3 flashes per side simultaniously before going back and forth in a wig-wag type pattern, it then repeats both these patterns every 4 cycles. Flash 3: The FLASH-3 does a standard back and forth wig-wag type pattern at a rate of 3 flashes per second. Installation instructions for Flash 1, 2,& 3: http://www.strobe.com/pdfs/flash-install.pdf Automotive Network, Inc., Copyright ©2012
