Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 06-03-2005, 03:03 PM   #1
cdbeard1
cdbeard1 Normal reputation
Question Need help removing drivers side airbag
I want to pull the steering wheel on my 98 S-10 Automatic but I can't figure out how to remove the airbag. My Haynes manual doesn't cover it. Any help ?
cdbeard1 is offline   Reply With Quote
Old 06-04-2005, 07:31 AM   #2
rlith
rlith's Avatar
rlith Normal reputation
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Need help removing drivers side airbag
Disconnect the battery for 1/2 an hour.
Rotate the steering wheel 90 degrees.
In each corner you will feel a hole. Insert a THIN and long phillips head screw driver (also torx screwdrivers work well) and firmly push out while you are pulling on that corner of the air bag. Move to the other side and do it again.
Rotate steering wheel 180 degrees and repeat.
Place airbag cover side down in safe area.
rlith is offline   Reply With Quote
Old 06-04-2005, 07:27 PM   #3
cdbeard1
Re: Re: Need help removing drivers side airbag
Thanks a bunch. Got me on the right track and now my steering wheel is straight when I'm going down the road.
Old 06-04-2005, 08:36 PM   #4
rlith
rlith's Avatar
If you were doing that to align your steering wheel, more than likely your regular alignment is out.
Bookmarks
Google
Web AF
