Could ThiS Be The Problem or Can iT Be Something Else?LYRICALDETOX 06-03-2005, 10:52 AM I have codes on my 96 Aurora so its not passing emissions. P0171 System too Lean P0174 System too Lean P1350 Ignition Control System P1375 Ignition Control (IC) Module 24x Reference High Voltage Other Aurora owners with the same codes posted their problems on the messageboard and as a result found the problem. So my question iS, can I be experiencing the exact same problem they had or can it be something different. I am not a car expert so any information would be great help. From my research, this is what i came up with P0171 & P0174 The cause was a bad valve on the intake manifold. The gasket had pulled away from the valve. source http://www.automotiveforums.com/t404309-lean_condition.html P1350 & P1375 a short in one of the connectors that plug into the ignition module source http://www.automotiveforums.com/t242249.html Automotive Network, Inc., Copyright ©2012
