Trans swap - Auto to Manual in a '92 can it be done?
Logray
06-01-2005, 08:26 PM
Was wondering if anyone knows/has a attempted to swap a 4 speed auto trans for a manual one, i have a manual trans out of a 4 cylinder caravan and when I looked at the car it came out of it seemed to have the exact bolt up location under the hood as my 3.0L V6. Will i need new driveshafts too or can the auto ones be used? And will i need any other parts (other than clutch pedal etc.). Oh and can the flywheel bolt up to my v6?
jawss
06-03-2005, 09:07 AM
Man, you are bored arent you! heheheheh If you really want to attempt this, you'd better cover all your angles. First and formost being your electrical conversions, mainly the computer. Next, I wouldnt bother trying the manual from a 4 cylinder if you can find a manual tranny from a 3L motor, like in a Daytona or similar. The 4 cyl. tranny may look the same but may not be able to handle the increased power of the 6 cylinder. I know you probably want to swap trannys because of the problems with the automatics but I would suggest trying to put in a 3 spd if you're not happy with the 4 spd. May be a lot less problems. Good luck with it!
