Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 06-01-2005, 10:37 AM   #1
goshman
goshman Normal reputation
blinking brake light indicator
My dash brake light indicator blinks 6 fast and 1 long over and over. Anyone know what this code means?
goshman is offline   Reply With Quote
Old 06-01-2005, 12:11 PM   #2
2000CAYukon
2000CAYukon Normal reputation
Re: blinking brake light indicator
It would help to know year and model (C or K, 1500/2500/3500).
//2000CAYukon
2000CAYukon is offline   Reply With Quote
Old 06-01-2005, 09:38 PM   #3
goshman
Re: Re: blinking brake light indicator
//2000CAYukon
sorry its a 91 k1500
Old 06-01-2005, 09:46 PM   #4
mbumgua
mbumgua's Avatar
mbumgua Normal reputation
Usually indicates a antilock fault of some kind
mbumgua is offline   Reply With Quote
Old 06-02-2005, 01:51 AM   #5
roadrunner_70
roadrunner_70 Normal reputation
Send a message via Yahoo to roadrunner_70
ABS codes are retrieved similar to the check engine light codes, however, finding the fault codes for them are a little more difficult. You might try Mitchell Repair Manual for your year and make. I had a fault in mine once after washing the undercarriage. Unplugging the fuse for twenty to thirty seconds, with the engine off, then plugging it back in, will determine if it's a transient code. If it isn't, it will return.
roadrunner_70 is offline   Reply With Quote
Old 06-02-2005, 12:09 PM   #6
2000CAYukon
I have a 90 Factory Service Manual at home. I can look up the code later tonight and post the results.
//2000CAYukon
Old 06-03-2005, 01:16 AM   #7
2000CAYukon
According to my 90 FSM, you have a code 7 which is Shorted Isolation valve or faulty ecu.
The Isolation valve is near the control module between the master cylinder and steering gear box.
I would check the electrical connections at the valve first.
//2000CAYukon
Bookmarks
Google
Web AF
