90 cherokee stuck in 4wdlussenden 06-01-2005, 01:24 AM i just got a 1990 cherokee laredo and i was trying to see how the 4wd worked, like how to put it in and take it out of 4wd. so i put it into 4wd just fine and it worked. then i tried to put it back into 2wd and it wouldnt go back, it still said "part time". i have no idea how to get it back into 2wd. i tried every combo of gears and trying to put it back into 4wd and it didnt grind or make any wierd noises. i dont know what to do. please help chili 06-01-2005, 04:36 AM i just got a 1990 cherokee laredo and i was trying to see how the 4wd worked, like how to put it in and take it out of 4wd. so i put it into 4wd just fine and it worked. then i tried to put it back into 2wd and it wouldnt go back, it still said "part time". i have no idea how to get it back into 2wd. i tried every combo of gears and trying to put it back into 4wd and it didnt grind or make any wierd noises. i dont know what to do. please help I too have a 90 Cherokee and had problems with it getting out of 4wd it kept getting stuck in part time and was a REAL PITA (Pain In TheA$$) come to find out i had swapped the spare on after a blow out and it was a different diameter ...... made it ALMOST impossible to shift out of 4wd....the only way i could get it to do it was to cycle thru all lvls of 4wd including 4lo and then back to 2 hi and reversing hard..... Hope it helps Chili runuover 06-01-2005, 08:28 AM [get under it and move the handle with a pry bar on the transfer case] see if that works. lussenden 06-06-2005, 12:26 PM i just got a 1990 cherokee laredo and i was trying to see how the 4wd worked, like how to put it in and take it out of 4wd. so i put it into 4wd just fine and it worked. then i tried to put it back into 2wd and it wouldnt go back, it still said "part time". i have no idea how to get it back into 2wd. i tried every combo of gears and trying to put it back into 4wd and it didnt grind or make any wierd noises. i dont know what to do. please help thanx for the help, i just messed around with it by going through all of the gears and it just came out of 4wd. thanx for the help gtmud 06-06-2005, 06:12 PM The 90 Xj does yours have vacuum lines going to the front axle on the PS side? If so, you could either have a vacuum switch that is sticking, or the actuator onthe front axle going bad.The vacuum switch is located on the back DS of the T-case, has 4-5 vacuum lines going to it. If its bad, just simply unscrew it and see if the plunger ball in the bottom is sticking. Automotive Network, Inc., Copyright ©2012
