94 pickup gear shift removalpayne 05-30-2005, 07:30 PM How do I remove the gear shifts on my 94 4wheel drive toyota pickup. I am replacing the chutch and I'm having problems removing the two gear shifts. Thanks for any help! Brian R. 05-30-2005, 11:16 PM Welcome to the AF! REMOVE TRANSMISSION SHIFT LEVER FROM INSIDE OF VEHICLE (a) Remove the four screws and remove the shift lever boot retainer. (b) Pull up the shift lever boot. (c) Cover the shift lever cap with cloth. (d) Then, pressing down on the shift lever cap, rotate it counterclockwise to remove. (e) Remove the shift lever. REMOVE TRANSFER SHIFT LEVER FROM INSIDE OF VEHICLE Using pliers, remove the snap ring and pull out the shift lever from the transfer. Automotive Network, Inc., Copyright ©2012
