Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 05-30-2005, 06:58 PM   #1
Lostone01
Lostone01 Normal reputation
Send a message via AIM to Lostone01 Send a message via Yahoo to Lostone01
Doorlocks and Cigarette lighter
Ok, here is a question for you all....when I bought my 94 Grand Am a year ago, everything on it worked. I made the mistake of jumping a small curb with it one day and since then the electronic door locks and the cigarette light stopped working. How and where are they connected to each other? I checked the fuses at the dash and they all look good. Where am I missing something? Thanks
LostOne01
94 Grand Am with 165,000 miles on it
Lostone01 is offline   Reply With Quote
Old 05-30-2005, 08:15 PM   #2
skibum1111
skibum1111 Normal reputation
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
The lighter and locks stopped working on my 95 some time ago, turned out to be a dime in the lighter socket, shorted things out every time i hit a large bump or took a really hard right turn. They both run on the same circuit, if there is nothing in the lighter causing it to short and the fuse is good, there is a problem between the fuse box and where the wire splits.
skibum1111 is offline   Reply With Quote
Old 05-30-2005, 09:11 PM   #3
evansdad
evansdad Normal reputation
Send a message via Yahoo to evansdad
Re: Doorlocks and Cigarette lighter
The horn should be on the same fuse. Maybe its in the horn. Check and see if the horn is working.
evansdad is offline   Reply With Quote
Old 05-30-2005, 11:14 PM   #4
Lostone01
Well there is nothing in the lighter to short it out and the horn works just fine....so I guess I gotta take a few hours and trace down the wiring. Thanks guys
Old 05-31-2005, 08:28 AM   #5
GASE 95
GASE 95 Normal reputation
i had the same problem with my 95 when i dropped a penny in the cig lighter after charging my cell phone. The ONLY option my car has is power locks and they dont work now lol
GASE 95 is offline   Reply With Quote
Old 06-03-2005, 12:33 AM   #6
swalt
swalt's Avatar
swalt Normal reputation
Do a search on chime module and that may help you.
swalt is offline   Reply With Quote
Old 04-13-2006, 11:32 PM   #7
bak2good
bak2good Normal reputation
Send a message via ICQ to bak2good Send a message via AIM to bak2good Send a message via MSN to bak2good Send a message via Yahoo to bak2good
I had a dime fall into my cigarette lighter and short my locks and of course the lighter. Turned out it was the courtesy fuse that was blown. I can't recall whether or not the interior lights worked, but I bet they didn't. Anyway, after we replaced that fuse everything worked fine. That was months ago. Now my problem is my cigarette lighter is not working because I need to replace the plug itself (the place where the found its home). The inside of the plug just broke up probably from things steadly falling inside of it. I just hope I can find the correct part. The only thing I have found on the internet so far is the electrical connector and that is not broken. I hope everyone was able to get their problems fixed. Bye for now.
bak2good is offline   Reply With Quote
Old 04-14-2006, 12:17 AM   #8
xeroinfinity
out saving the world
xeroinfinity's Avatar
xeroinfinity Normal reputation
Hav you checked the fuse box under the hood?
has to be a short if no fuses or relays are toast.
Good Luck, tracking electrical shits not fun
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
Old 04-14-2006, 07:27 AM   #9
bak2good
I forgot to mention that right now the only problem is that my cigarette lighter does not work. Everything else in the car is fine.
Bookmarks
Google
Web AF
