Start ProblemMIKE HASCHAK 05-30-2005, 04:13 PM '97 Ram 5.2 Ran Fine Week Ago. Parked At Home For 1 Week And Will Not Start To Get Assistance W/scanner. The Spark Is Present And All Cylinders Show 130+ Psi Comp. Plugs Are Clean And Wet After Cranking. Fuel Is Same As Has Been Driven With. Can't Imagine What Else To Check For. Never Even Tries To Fire. Thanks, Mike BleedDodge 05-30-2005, 06:55 PM The catalytic converter has plugged I bet. MIKE HASCHAK 05-30-2005, 07:13 PM The catalytic converter has plugged I bet. AND HOW MIGHT DETERMINE THAT TO BE TRUE? THERE WAS NO INDICATIONS OF WEAKNESS OR POOR PERFORMANCE. BETWEEN ROCK AND HARD PLACE HERE. THANKS BleedDodge 05-30-2005, 08:36 PM Get someone to crank it over while you hold your hand over the tailpipe. See if you can feel anything come out. MIKE HASCHAK 05-30-2005, 08:51 PM Get someone to crank it over while you hold your hand over the tailpipe. See if you can feel anything come out. DID SO AND FOUND A VERY POSITIVE EXHAUST PRESSURE. KEEP IN MIND THAT IT NEVER EVEN TRIES TO FIRE OFF. THERE IS SPARK AT EVERY PLUG AND PLUGS GET WET AFTER ENOUGH CRANKING. I WAS UNDERSTANDING, WHERE THERE IS FUEL AND SPARK, THERE'S FIRE. IF IT WOULD AS MUCH AS "SPUT", I'D BETTER UNDERSTAND. AGAIN, THANKS BleedDodge 05-30-2005, 09:56 PM It's plugged. Hyginkz 06-08-2005, 08:31 PM Drop your exhaust in front of your cat and see what happens if you crank it. If it don't do any thing, it ain't the cat. These weird ones are never easy till fixed. Automotive Network, Inc., Copyright ©2012
