1989 ram-50 rough idle until warmmoose82 05-30-2005, 02:00 AM My uncle's truck was runing rough, replaced plugs and truck still running rough until engine warmed up and then idles at 1000RPM. and runs great. I'll let it cool down and same thing all over. What else do I need to check or replace? Seems like she is running rich as well. Has 127,000 miles. 2nd question..the truck is very jumpy especially over small bumps..wondering if replacing the rear shocks will improve it or is the truck just too worn out.. any help would be much appreciated...thanks in advance fredjacksonsan 06-01-2005, 07:50 AM Try replacing cap and rotor also, that is where I'd start with the rough idle while cold. Is it carbureted or fuel injected? When you say "very jumpy" what exactly do you mean - does the rear end continue to bounce after going over bumps? HansonHVAC 06-01-2005, 01:21 PM If its running rich check your oxygen sensors moose82 06-02-2005, 05:54 PM If its running rich check your oxygen sensors I replaced the cap and rotor as well...takes a few minutes of driving to finally idle nicely... The truck jumps around after going over bumps and the front is even worse going to make an apointment to bring the truck in to check the oxygen sensors thanks.. Automotive Network, Inc., Copyright ©2012
