Electric Fan is on all the time.(93 Olds Ciera)
Ron Lindquist
05-30-2005, 01:40 AM
Hi, for the last week or so, the electric fan by the radiator is on all the time, even when it's cold and I just start it.?
Could it be some kind of sensor ? Can't seem to find one around the fan. Can someone help ?
Thanks, :screwy:
burntclayman666
05-30-2005, 02:30 PM
You'll have to replace the fan relay.
SupremeCutlass
06-06-2005, 01:07 PM
I had to replace my relay too, just as a word of advice, GM will rip you about 10-15 bucks for it. Advance auto parts will give it to you for a much cheaper price.
SupremeCutlass
06-17-2005, 01:26 AM
If it's not the relay, then then next step would be to check your thermostat; It may be suck open.
bud duggley
07-14-2005, 10:02 PM
Does anyone know where the cooling fan relay would be for a '92 Ciera?
I looked all over under the hood and can't find one. I 'spose I could go to the library and see if the Chiltons manual might have it.
Chris Stewart
07-14-2005, 10:16 PM
My book shows it behind the passenger side headlight, 2nd from the outside.
djnoname
08-31-2005, 12:23 AM
Genuinly those relays will prevent the fan from coming on at all once they are toast but it is possible. My $$ is on the CTS sensor cuz its causing your car ecm to misread coolant temp. good luck.
