Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 05-29-2005, 05:20 PM   #1
brots06
brots06 Normal reputation
Send a message via AIM to brots06
Question Hesitation on take off??
I have a '99 grand am gt and once in awhile usually right after i start the car or within 5 minutes after i start it the car hesitates when i give it gas, it acts as if its out of gas but its not. Any ideas?
-Thanks
brots06 is offline   Reply With Quote
Old 05-29-2005, 05:50 PM   #2
Ridenour
GranddAmnit
Ridenour's Avatar
Ridenour Normal reputation
Send a message via MSN to Ridenour
Re: Hesitation on take off??
A couple things could be causing this, Brots.
Your TPS (throttle position sensor) could be bad
Your fuel pump could be dying
Your fuel pressure regulator could be going
Your wire(s), plug(s), or coil(s) could need changing
Your fuel filter could need changing
Your injector(s) could be clogged / dirty.
There's really quite a lot of possiblities. Do you have any stored engine codes / SES lights during the occurance?
Ridenour is offline   Reply With Quote
Old 05-29-2005, 06:21 PM   #3
brots06
hmmm, i just had a new head gasket put on, new spark plug wires and a new fuel filter, do you think they messed something up when they did that?
Old 05-30-2005, 12:15 AM   #4
shep18
shep18 Normal reputation
Send a message via MSN to shep18
I have the same problem bro, and i have a 96 grand am 3.1 L and i have changed plugs, wires, ECM and coils, TPS, fuel pump and fuel filter and i still have the same damn problem. So i just took off the intake manifold this weekend to go get my fuel injectors professonally cleaned and rebuilt and flow tested, when there done and it's all back together i will reply back and let you know if it fixes my problem, cause it sounds just like your problem and it has only been getting worse over the last 5 months now where it has like no power and hesitates like hell. Ill keep you posted though.
shep18 is offline   Reply With Quote
Old 05-30-2005, 12:17 AM   #5
shep18
ohh yeah i will be putting on a new fuel pressure regulator too when i put the injectors back in so if it does fix it it could be the rugulator or the injectors. But i will let you know the outcome later this week
Old 05-30-2005, 08:43 AM   #6
Knifeblade_03
Knifeblade_03's Avatar
Knifeblade_03 Normal reputation
Send a message via Yahoo to Knifeblade_03
Old School here, run a good concentrated injector cleaner at least every 3 tankfuls, GM newer injectors love to gunk up with average gas. It's just good maintenance.
Attack Pig {aka Tam}
**Disclaimer** An honest opinion is not always appreciated by the recipient.
Knifeblade_03 is offline   Reply With Quote
Old 05-30-2005, 03:07 PM   #7
evansdad
evansdad Normal reputation
Send a message via Yahoo to evansdad
I would bet on it that its the crank position sensor.
evansdad is offline   Reply With Quote
Old 08-08-2005, 03:34 PM   #8
deb789
deb789 Normal reputation
Im not recieving an check engine light. How much is the crank postion sensor?
deb789 is offline   Reply With Quote
Bookmarks
Google
Web AF
