1992 s-10 blazer squeaky front axel
bodyguard890
05-29-2005, 05:09 PM
When in motion the front axle or something connected to it seems to be squeaking with every revolution, not sure what it is, I did however roll down my drive way one day with the parking break on :nono: ( could have something to do with it....). Let me know what you think. :confused:
AJT1961
06-02-2005, 02:26 AM
The parking brake has nothing to do with it since that works on the rear brakes. The noise may be from the front brakes. Does the squeak go away when you gently press the brake pedal? If so, that's your noise. If that is it, check your front brake pads for wear. If the pads are okay, you can either live with the noise (it is harmless and may go away by itself), or remove the calipers, clean everything, and apply a "Stop Squeak" liquid adhesive product to the backs of the pads. Frankly, if you do that, you might as well throw in new pads unless they are almost new. All of the above assumes, of course, that the front brakes are the culprit. If the noise doesn't go away when you gently press the brake pedal, you'll then need to look at the front wheel bearing assemblies. Let us know how it turns out.
bodyguard890
06-02-2005, 11:28 AM
yea man when i hit the brakes it goes away, alright sweet, im gettin checked tommrow ill let u kow how it turns out thanks for da help
