Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 05-29-2005, 01:05 PM   #1
ajamato86
ajamato86 Normal reputation
Send a message via AIM to ajamato86
lifting an s-10
i have a 1998 2 wheeldrive s-10 reg cab, and i was wondering whats the cheapest and esiest way to lift the truck a little, around 2 inches with minimal effect to ride quality
foxtrot delta lima
ajamato86 is offline   Reply With Quote
Old 05-29-2005, 09:48 PM   #2
m3gumby
m3gumby Normal reputation
Re: lifting an s-10
get a body lift
m3gumby is offline   Reply With Quote
Old 05-30-2005, 12:21 AM   #3
ajamato86
Re: lifting an s-10
i want a suspension lift, not a body lift
foxtrot delta lima
Old 05-30-2005, 12:36 AM   #4
OverBoardProject
Banned
OverBoardProject Normal reputation
Re: lifting an s-10
Spindles up front, and shackles in the back
http://www.truckn-store.com/product_list.asp?id=2205
Also try a google search for the parts
OverBoardProject is offline   Reply With Quote
Old 05-30-2005, 10:51 AM   #5
ajamato86
Re: lifting an s-10
by usuing spindles and shackles do i need new shocks or can i keep my stock ones, and for the spindles...do i need to add extra brake line?
foxtrot delta lima
Old 05-30-2005, 11:11 AM   #6
OverBoardProject
Banned
Re: lifting an s-10
You will probably need different shocks with the shackles, but probably not with the spindles.
Spindles should keep the geometry the same, although I would still get an alignment.
And with the brake lines, it really depends on how long your are to start with. They are often made longer that they have to be. You might need a longer 1 in the back too.
If you need longer brake hoses your local parts store can make them up for you. If not just get a steel line extension made up.
Old 06-01-2005, 04:15 AM   #7
whitetrash982
whitetrash982 Normal reputation
Send a message via AIM to whitetrash982
lift
with spindles and shackles , you will need longer shocks...if you go over a bump to big to fast , you could pull the shock tube right out of the case , you might not need new brake lines , with such a smalll lift , you may be able to get away with bending the brake line bracket to work or mount it lower , and you dont need an alignment with just the spindles , least you shouldent if you get a quality part , all lift spindles do is take the factory spindle and lower the spindle arm on it , but for s-10 , they usually only make 3" spindles , and 2" shackles , but you should be ok cuz the front usually rides a bit lower in the front then the back , and heres a good website to look for parts.... www.truckin.com
whitetrash982 is offline   Reply With Quote
Old 06-01-2005, 07:12 PM   #8
ajamato86
Re: lifting an s-10
alright, 1st of all how much would it cost to get spindles and shackled installed, what type of shock would i need?
and if i raised my truck and put tires that are a little larger on...like a 225 or 235/75/15 would it affect my fuel milage or power in any way?
foxtrot delta lima
Old 06-03-2005, 06:25 PM   #9
ajamato86
Re: lifting an s-10
also, is there any cheaper place other then truckin.com to get spindles, they cost 300$. what is the average price for spindles...and is there any cheaper alternative for the front end
foxtrot delta lima
Old 06-04-2005, 08:26 AM   #10
rlith
rlith's Avatar
rlith Normal reputation
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: lifting an s-10
Try www.jegs.com and www.summitracing.com. 300 bux for spindles though is about right.
rlith is offline   Reply With Quote
Old 06-04-2005, 06:06 PM   #11
ajamato86
Re: lifting an s-10
cause of the price of spindles i might lift the rear this summer and the front next summer, would lifting the rear 2 inchs and not the front make the truck look too rediculous lol? also, when lifting do i need any extra components like sway bars etc..i dont know to much about suspension so all the help is needed and greatly appreciated
foxtrot delta lima
Old 06-05-2005, 12:31 PM   #12
dmbrisket 51
dmbrisket 51's Avatar
dmbrisket 51 Normal reputation
Send a message via AIM to dmbrisket 51
Re: lifting an s-10
if you want to know how it would look, stick a jack under your rear bumper, and with a tape measure, pump untill it hits 2 inches higher then it was, and there ya have it, what it would look like liften the rear 2"
dmbrisket 51 is offline   Reply With Quote
Old 06-05-2005, 02:54 PM   #13
OverBoardProject
Banned
Re: lifting an s-10
dmbrisket 51 is right, that'll give you an idea how it'll look
I wouldn't even consider just lifting the back this year. In my opinion that'll look awful.
If money is the issue give it that much dreaded body lift until you can afford to do it right. You might just be happy with that alone, or want to go higher anyways.
Once you lift a truck once it's never high enough until you need a ladder to get in
Old 06-05-2005, 04:23 PM   #14
dmbrisket 51
Re: lifting an s-10
exactly why i told him to do it, it wouldnt look right, only time you put the back end up like that is when your 68 camaro has 600 rwhp and its set on a stright line with slicks on it, not a truck, not a later model street truck for sure
Bookmarks
Google
Web AF
