check engine light
joel poulson
05-29-2005, 11:35 AM
hi guys, my check engine light is on in my 01 3.5 aurora. also is starting harder than usual. any ideas?
GTP Dad
05-29-2005, 01:19 PM
It would be helpful to know the computer code as it makes it much easier to diagnose. If you don't have a code reader go to autozone or advance and they will scan it for free.
55624096
05-29-2005, 05:49 PM
Usual cause of hard warm engine restart is bad fuel pressure regulator. pull off vaccum line and if you see fuel in tube you have a leaking diaphram in presssure regulator. change it about $45.00 on GM parts direct and your problem will be solved. Check engine lite must be solved via computer code reader.
joel poulson
06-06-2005, 01:30 PM
thanks for the reply, do i need a obdii reader. thanks, joel
GTP Dad
06-08-2005, 06:57 AM
If you want to read the codes yourself you will need a reader. Autozone will read them for free as long as the CEL is on.
