pushrods,rocketarms
Google
Web AF
Huge88
05-28-2005, 10:44 PM
I have an 88 350eng tbi,what size pushrods and rocker arms should i run i have a new motor and heads the heads are 74 cc heads and it has a stock size cam in it the stroke is stock as well ,what should i put in there was thinking about longer rockers but dont know what that would do any good if its all stock ?
Thanks
bracketshark
05-29-2005, 08:57 AM
Stock rockers are 1.5 raio in a 350 chevy motor (they vary a little in the stamping process), the push rod length is 7.800", I think. I wouldn't recomend changing ratio's on a stock motor, machine work to the heads is "sometimes" required to clear the pushrods where they pass through the casting. Push rod lenght does little for performance other than relocating the contact position of the rocker to the tip of the valve. If you wanted to add perfomance parts it should have been a consideration during the rebuild process. Just my 2 cents worth though. Good luck! :cool:
Google
Web AF
