intake gasket?igkyoa 05-27-2005, 03:41 PM i have oil leaking from the gasket above my cylinder heads and possibly from the one below them too. normally i would not be worried with a little oil leaking but its leaking enough oil that it's running down the block and dripping on the floor. is this the same intake gaskets problem that everyone else is having? bearcatdon 05-28-2005, 07:49 PM When the intake gasket blows, oil will mix with the antifreeze in the engine. Coolant may be apparent on the top LH side of the motor. It sounds like your valve cover gaskets may be leaking. Those can be replaced quickly especially if it’s the front. Automotive Network, Inc., Copyright ©2012
