removable doors
runuover
05-26-2005, 12:03 PM
i have a 87 cherokee 4 door and i would like to remove my doors when i go trail riding. is there a easy way to do that instead of taking the bolts off and on again all the time.thanks for the info :nutkick:
scuba4321
05-26-2005, 07:29 PM
I have seen pictures of Cherokees with the doors off before, but unless you can fabricate something , I bet you will have to break out a socket and wrench every time
runuover
05-27-2005, 09:47 AM
[thanks thats what i figured that sucks :banghead: ]theres got to be a way to do it
BUCKYXJ
05-29-2005, 11:55 AM
yup I did it. do a search of www.naxja.org for it and its got tons of info. you gotta cut the bottom of the bracket on the door off so it can slide on and off of the hinges
Silver_XJ
08-26-2005, 09:01 PM
My 88 Laredo 5spd. has removable doors... Simple as anything do do. Drill out your hinge pins and put in 1/4 inch grade 8 bolt that you can pull out on demand. Just make sure you grease them ALOT or you will wear through them. I made quick plugs for all the wiring too. dont have to drill out the hinges much. just enough to put in a grade 8 , 1/4 inch bolt.
- Silver XJ
runuover
08-27-2005, 11:55 AM
- Silver XJ
thanks for the info.
