1992 corvette won't turnover
Rodeo254
05-25-2005, 07:21 AM
Hello:
I am new to the forum and have a question?
I own a 1992 Corvette. I stored it in my garage over the winter and in the spring I went to start it, but the battery seemed to be dead. I replaced the battery with a new one and still the beast did nothing. All the lights, radio, wipers, power antenna everything else works fine but the car won't turnover. The vehicle started fine when I parked it for the winter. If anyone has a clue our some suggestions it would greatly be appreciated. Thanks. :confused:
1963
05-25-2005, 10:06 AM
You have a bad solinoid on your starter...
Rodeo254
05-27-2005, 12:52 PM
Thanks for the input 1963, I tryed a new starter on my car and still have the same problem (won't turnover) even with the headlights on and trying to start the car it doesn't even dim the lights down. I'm beginning to believe it might be the vats system but I'm not sure. Any other suggestions?
vvcowboy
05-28-2005, 09:16 AM
I have a 92 also,, some time's it won't turn over,, but I now know it's in the switch,,, if I turn it just right,, it will start,,,hope this help's ya a little....
chevydog001
10-13-2005, 10:00 PM
you have a bad connection to your knock sensor. it is right above the starter on the engine block. tap or wiggle the wire and it should start. if you want to replace the pigtail, it will go out completely, go to the junk yard for one or your gm dealer. pn 12102621 it is $16.76 well worth not having to lay in the snow or rain to wiggle the wire. hope this helps.
