UNDER HOOD, DRIVER SIDE, REAR SIDE OF STRUT TOWER, DRIVER SIDE OF BRAKE MASTER CYLINDER, MOUNTED ON UPPER FIREWALL
it should be located with another relay, along with the ESC (electronic spark control module) you could try to switch the two relays (I believe they are the same), turn the ignition on, and listen for the pump, if you don't hear it, you probably have a bad pump, and I'm sorry to say that they are not fun to replace.
P.S. I am almost positive that there is no fuel shut off switch.
good luck
