Trouble with my turbo
theTEH
05-23-2005, 04:16 PM
I just installed a turbo kit in my sohc civic, but I am having problems with it. When I start it up it right away revs to 4k rpm's and holds it for 5 seconds. After that it idles revs up to 3k rpm's and drops back to 1k, then back to 3k, and so on. At first i thought it was an air leak in my intake manifold, but i changed the gasket and now my turbo just smokes when I start the car, and sounds like a lawn mower if I try and drive it. I can't get a hold of my personal mechanic, so was wondering if anyone has a suggestion.
97integrals
05-23-2005, 06:00 PM
What is you full set-up including management?
V T E C H
05-23-2005, 06:08 PM
do you have the check engine light coming on?
theTEH
05-23-2005, 06:20 PM
Yeah, check engine light stays on and white smoke comes out exhaust and engine is burning up seconds after start up.
theTEH
05-23-2005, 06:28 PM
I have the edelbrock performer X turbo kit, which includes just about everything.
97integrals
05-23-2005, 08:00 PM
what are you running for engine management? Has the car been tuned?
theTEH
05-24-2005, 12:54 AM
No, it has not been tuned yet, only had it in for a couple of days.
97integrals
05-24-2005, 01:00 AM
AND WHAT ENGINE MANEGMENT ARE YOU RUNNING!!!!
theTEH
05-24-2005, 12:02 PM
Sorry, it has an auxilary engine management computer that came w/the kit. If you want to check it out its at http://www.edelbrock.com/automotive/sport_compact/index/html
V T E C H
05-24-2005, 04:23 PM
are you sure this isnt a problem with your IAC valve?
97integrals
05-24-2005, 04:36 PM
Pull the cel code to find out why the car is idling funny, it could be a number of sensors, if you using the stock map sensor chances are that is the problem. As for the smoke check for leaking oil lines and if the turbo is used it could be the seals on the turbo. After you get these problems fixed it is very important that you get the car tuned.
superbluecivicsi
05-24-2005, 04:43 PM
recheck all your vac lines and sources.
scottsee
05-25-2005, 06:06 PM
burrning white smoke means your burring coolent.
