Rear "rumble" type noise when stopped in DRIVEkopertone1 05-23-2005, 02:23 PM When I am stopped in drive there is some times a rear rumble noise which is farily deep sounding. It does this only when in drive at a stop. Is tehre somthing lose back there rattling or? Thanks vamc 05-23-2005, 10:39 PM Check the trans mission fluid.. is it full. it could be a torque converter. just a thought. kopertone1 05-24-2005, 01:31 AM Ok well it sounds like its most defianly in the rear, My fluids are fine... where is that converter? vamc 05-24-2005, 04:50 PM In the transmission. kopertone1 05-24-2005, 06:42 PM yea but the transmission is in basically the front and this is definalty in the rear kopertone1 05-24-2005, 06:43 PM yea but the transmission is in basically the front and this is definalty in the rear Kings-x59 05-25-2005, 01:40 PM Have you checked for holes in the muffler? cmlind 05-25-2005, 04:11 PM I would guess the heat shield between the tailpipe and the gas tank is loose or rusted. It is common to make noise if the tailpipe and muffler are rusted out and bumping against something. It makes the noise at idle because of vibration when it idles. Look at the tailpipe and wiggle it. It is probably loose. kopertone1 05-25-2005, 07:32 PM Alright I'll take a look thank you... I tell you if thats it. Automotive Network, Inc., Copyright ©2012
