Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 05-23-2005, 10:54 AM   #1
apexi_mkIV
apexi_mkIV Normal reputation
Send a message via AIM to apexi_mkIV Send a message via Yahoo to apexi_mkIV
STRANGE GRINDING NOISE, help plz
I've searched quite a bit regarding this and can't find an answer.
When I start my integra after it sits for 30+ min and begin to drive (for or rev) I get a loud grinding type noise, especially if I turn the wheel. If I turn the wheel it makes a sustained grinding noise and if I just pull forward or backwards, it makes short spurts of the noise. The noise only lasts 10-20 sec after I begin driving and then goes away...
Now, the strange thing is, I have found if I let the car warm up for 3-5 min before pulling away it doesn't make this noise. At first I thought it maybe a wheel bearing since it sounds to be coming from the passenger side. But now that I know that it goes away after you let it warm up it makes me think it vould be a trans problem.
New trans fluid?
Something else?
Any help will be greatly appreciated...
apexi_mkIV is offline   Reply With Quote
Old 05-23-2005, 12:32 PM   #2
CBURKE
CBURKE's Avatar
CBURKE Normal reputation
Re: STRANGE GRINDING NOISE, help plz
Well it sounds like it could be a number of things (none of them good). Not really sure off hand, kinda need to be there to hear it. If you want turn the car on have a friend rev it up a little and get under the car see if it's anything in the bottom end. If not, then on to the top.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
CBURKE is offline   Reply With Quote
Old 05-23-2005, 01:33 PM   #3
apexi_mkIV
sound comes only when the car is in motion, wether its in gear or just rolling
Old 05-23-2005, 04:38 PM   #4
HondaTuner20
HondaTuner20 Normal reputation
it could be ur driveshafts.. i had the same problem with my 94 accord at. when i would turn it would grind had the drive shafts replaced solved my problem..
HondaTuner20 is offline   Reply With Quote
Old 05-23-2005, 05:55 PM   #5
97integrals
97integrals's Avatar
97integrals Normal reputation
New trans fluid?
Something else?
Sounds like your axles. Get the car in the air and inspect both axles (especially cv joints)
97integrals is offline   Reply With Quote
Old 05-23-2005, 06:52 PM   #6
kornflakes28546
kornflakes28546's Avatar
kornflakes28546 Normal reputation
does it make the sound when the car is rolling w/ the engine off?
kornflakes28546 is offline   Reply With Quote
Bookmarks
Google
Web AF
