Pictures
m3gumby
05-22-2005, 06:52 PM
Hey guys i was looking for pictures of the S-10 w/ a few custom options on the internet but i couldn't find it, and im sure yall have pictures that will help me out a lot. I am actually looking at the S-10, and after i buy one i am looking into putting some A/T tires on it. I like the 15x8 black rims w/ 33 x 12.5 tires. Will these fit w/out adding a lift? I dont want to lift it real high, i just want an S-10 that has big tires that is still functional. I like subtle, not extreme. Thanks for any help.
xtrememeasures10
05-22-2005, 07:52 PM
www.cardomain.com
Thousands upon thousands of s 10s there. enjoy.
OverBoardProject
05-22-2005, 10:15 PM
You'll probably need about 3, and possibly 4" of lift for those tires. I would try a 2" suspension lift first and if you need more height use a body lift
They sure look good when they're done though.
whitetrash982
05-23-2005, 01:07 AM
you need a 6" lift to clear 33's , and even then they may rub on the lower portion of the front bumper , and unless you have the proper offset wheels , theyll rub on the frame when you turn , i know from personal experience that a 2" lift will clear 31's , also the prob with bigger tires - the bigger the tire , the more stress your gonna put on the suspension components - wheel bearing and axle bearings - youll wear them out much quicker then normal , but yeah , far as tires , i had very good luck with BFG a/t's , excellent on and off road traction , good tread wear , and virtually no road noise , anyways , good luck
OverBoardProject
05-23-2005, 01:53 AM
I don't like BFG tires, but your right about them. That's what came on my Blazer, and that thing amazes me where it goes.
m3gumby
05-23-2005, 01:15 PM
ive been looking for cardomain.com forever. I couldn't remember the name of the site to save my life. Are 33's too big for an S-10? should i go down to like a 31? what does the ZR2 have on it?
rlith
05-23-2005, 10:32 PM
For a 33" tire you will need a 4-6 inch suspension lift and a 2" body lift with some fender trimming. Even with that you will have some frame rub.
movin2stereo
05-24-2005, 06:23 AM
Zr2s have 31s.They just clear on the front.
m3gumby
05-24-2005, 09:02 PM
how much lift does the ZR2 have? i like the look of the ZR2 but im lookin for a black rim so why not just do it myself?
rlith
05-24-2005, 09:18 PM
the zr2 is about 3" higher than a stock s10
http://www.zr2.com/images/home_page/s10_zr2.jpg
m3gumby
05-25-2005, 06:19 PM
31 inch tires with a 3 inch lift would get me the same set up as a ZR2, i like this. Is there anything else that you would reccomend doing if i were to start this set up?
m3gumby
05-29-2005, 09:45 PM
what width is the ZR2's wheels?
m3gumby
05-29-2005, 10:37 PM
can yall give me a website that has S-10 lift kits on it, as well as S-10 mods? Thanks
OverBoardProject
05-30-2005, 12:31 AM
Try these guy's.
http://www.truckn-store.com/product_list.asp?id=2187
You'll want their control arms, torsion bar keyway lift, and probably shackles for the back. If you plan on hauling lots or towing get extra springs in the back instead of shackles, although the ride is harder
Also try a Google search, there are several other companies out there
m3gumby
06-01-2005, 11:35 PM
what is the difference in a regular S-10, and a ZR2 other than the bigger tires, as well as body lift?
rlith
06-02-2005, 07:51 AM
No body lift stock on the zr2...
RPO ZR2 only full ladder-type frame with modified suspension mounting points which provide:
100mm wider track (3.9 inches wider than regular S-10)
Three-inch suspension height increase
Enhanced front (7.25" ring gear) and rear (8.5" ring gear) axles w/ 3.73:1 rear-axle ratio
Larger wheel and axle bearings
31 x 10.5R-15 LT/C black wall off-road tires (BFG A/Ts on pickups and BFG Long Trails on BlaZeR2)
46mm gas pressurized Bilstein Monotube shocks
Rear axle track bar (pickups) / rear sway bar (BlaZeR2)
Wheel flares (black on S-10 pickups and BlaZeR2 / body-color on Sonoma pickups)
33mm (early model) / 28mm (late model) front anti-sway bar
Skid plates
