Diagnostic Trouble Code list 2k c/kmjgjr72 05-22-2005, 01:56 AM it's a long list Engine Controls - 4.3L DTC P0101 Mass Air Flow (MAF) Sensor Performance DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency DTC P0106 Manifold Absolute Pressure (MAP) System Performance DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage DTC P0121 Throttle Position (TP) Sensor Performance DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage DTC P0125 Engine Coolant Temperature (ECT) Excessive Time to Closed Loop Fuel Control DTC P0131 H02S Circuit Low Voltage Bank 1 Sensor 1 DTC P0132 H02S Circuit High Voltage Bank 1 Sensor 1 DTC P0133 H02S Slow Response Bank 1 Sensor 1 DTC P0134 H02S Circuit Insufficient Activity Bank 1 Sensor 1 DTC P0135 H02S Heater Performance Bank 1 Sensor 1 DTC P0137 H02S Circuit Low Voltage Bank 1 Sensor 2 DTC P0138 H02S Circuit High Voltage Bank 1 Sensor 2 DTC P0140 H02S Circuit Insufficient Activity Bank 1 Sensor 2 DTC P0141 H02S Heater Performance Bank 1 Sensor 2 DTC P0151 H02S Circuit Low Voltage Bank 2 Sensor 1 DTC P0152 H02S Circuit High Voltage Bank 2 Sensor 1 DTC P0153 H02S Slow Response Bank 2 Sensor 1 DTC P0154 H02S Circuit Insufficient Activity Bank 2 Sensor 1 DTC P0155 H02S Heater Performance Bank 2 Sensor 1 DTC P0157 H02S Circuit Low Voltage Bank 2 Sensor 2 DTC P0158 H02S Circuit High Voltage Bank 2 Sensor 2 DTC P0160 H02S Circuit Insufficient Activity Bank 2 Sensor 2 DTC P0161 H02S Heater Performance Bank 2 Sensor 2 DTC P0171 Fuel Trim System Lean Bank 1 DTC P0172 Fuel Trim System Rich Bank 1 DTC P0174 Fuel Trim System Lean Bank 2 DTC P0175 Fuel Trim System Rich Bank 2 DTC P0300 Engine Misfire Detected DTC P0325 Knock Sensor Module Performance DTC P0327 Knock Sensor (KS) Circuit DTC P0336 Crankshaft Position (CKP) Sensor Performance DTC P0337 Crankshaft Position (CKP) Sensor Circuit Low Duty Cycle DTC P0338 Crankshaft Position (CKP) Sensor Circuit High Duty Cycle DTC P0339 Crankshaft Position (CKP) Sensor Circuit Intermittent DTC P0340 Camshaft Position (CMP) Sensor Circuit DTC P0341 Camshaft Position (CMP) Sensor Performance DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage DTC P0410 Secondary Air Injection (AIR) System DTC P0420 Catalyst System Low Efficiency Bank 1 DTC P0430 Catalyst System Low Efficiency Bank 2 DTC P0440 Evaporative Emission (EVAP) System DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected DTC P0446 Evaporative Emission (EVAP) Vent System Performance DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage DTC P0461 Fuel Level Sensor Performance DTC P0462 Fuel Level Sensor Circuit Low Voltage DTC P0463 Fuel Level Sensor Circuit High Voltage DTC P0500 Vehicle Speed Sensor (VSS) Circuit DTC P0506 Idle Speed Low DTC P0507 Idle Speed High DTC P0601 DTC P0602 Control Module Not Programmed DTC P0603 Control Module Long Term Memory Reset DTC P0604 Control Module Random Access Memory (RAM) DTC P0605 Control Module Programming Read Only Memory (ROM) DTC P0704 Clutch Switch Circuit DTC P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage DTC P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage DTC P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage DTC P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage DTC P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage DTC P1133 H02S Insufficient Switching Bank 1 Sensor 1 DTC P1134 H02S Transition Time Ratio Bank 1 Sensor 1 DTC P1153 H02S Insufficient Switching Bank 2 Sensor 1 DTC P1154 H02S Transition Time Ratio Bank 2 Sensor 1 DTC P1336 Crankshaft Position (CKP) System Variation Not Learned DTC P1345 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation DTC P1351 Ignition Coil Control Circuit High Voltage DTC P1361 Ignition Coil Control Circuit Low Voltage DTC P1380 Misfire Detected - Hough Road Data Not Available DTC P1381 Misfire Detected - No Communication with Brake Control Module DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance DTC P1415 Secondary Air Injection (AIR) System Bank 1 DTC P1416 Secondary Air Injection (AIR) System Bank 2 DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge DTC P1508 Idle Speed Low - Idle Air Control (IAC) System Not Responding DTC P1509 Idle Speed High - Idle Air Control (IAC) System Not Responding DTC P1621 Control Module Long Term Memory Performance DTC P1626 Theft Deterrent Fuel Enable Signal Not Received DTC P1631 Theft Deterrent Start Enable Signal Not Correct Engine Controls - 4.8L, 5.3L, and 6.0L (that are not listed with 4.3L) DTC P0200 Injector Control Circuit DTC P0230 Fuel Pump Relay Control Circuit DTC P0335 Crankshaft Position (CKP) Sensor Circuit DTC P0342 Camshaft Position (CMP) Sensor Circuit Low Voltage DTC P0343 Camshaft Position (CMP) Sensor Circuit High Voltage DTC P0351 Ignition Coil 1 Control Circuit DTC P0352 Ignition Coil 2 Control Circuit DTC P0353 Ignition Coil 3 Control Circuit DTC P0354 Ignition Coil 4 Control Circuit DTC P0355 Ignition Coil 5 Control Circuit DTC P0356 Ignition Coil 6 Control Circuit DTC P0357 Ignition Coil 7 Control Circuit DTC P0358 Ignition Coil 8 Control Circuit DTC P0418 Secondary Air Injection (AIR) Pump Relay Control Circuit DTC P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit DTC P0562 System Voltage Low DTC P0563 System Voltage High DTC P0705 Trans Range Switch Circuit DTC P0706 Trans Range Switch Performance DTC P1120 Throttle Position (TP) Sensor 1 Circuit DTC P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage DTC P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage DTC P1125 Accelerator Pedal Position (APP) System DTC P1172 Sec Fuel Pump Insufficient/ No Fuel Flow DTC P1220 Throttle Position (TP) Sensor 2 Circuit DTC P1221 Throttle Position (TP) Sensor 1- 2 Correlation DTC P1258 Engine Coolant Overtemperature - Protection Mode Active DTC P1275 Accelerator Pedal Position (APP) Sensor 1 Circuit DTC P1276 Accelerator Pedal Position (APP) Sensor 1 Performance DTC P1280 Accelerator Pedal Position (APP) Sensor 2 Circuit DTC P1281 Accelerator Pedal Position (APP) Sensor 2 Performance DTC P1285 Accelerator Pedal Position (APP) Sensor 3 Circuit DTC P1286 Accelerator Pedal Position (APP) Sensor 3 Performance DTC P1431 Fuel Level Sensor 2 Performance DTC P1432 Fuel Level Sensor 2 Circuit Low Voltage DTC P1433 Fuel Level Sensor 2 Circuit High Voltage DTC P1514 Throttle Body Performance DTC P1515 Control Module Throttle Actuator Position Performance DTC P1516 Throttle Actuator Control (TAG) Module Throttle Actuator Position Performance DTC P1517 Throttle Actuator Control (TAC) Module Performance DTC P1518 Throttle Actuator Control (TAC) Module Serial Data Circuit DTC P1571 Traction Control Torque Request Circuit DTC P1635 5 Volt Reference 1 Circuit DTC P1637 Generator L-Terminal Circuit DTC P1638 Generator F-Termina! Circuit DTC P1639 5 Volt Reference 2 Circuit Automatic Transmission - 4L80-E DTC P0218 Transmission Fluid Overtemperature DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input DTC P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent DTC P0711 TFT Sensor Circuit Range/Performance DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input DTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input DTC P0716 Input Speed Sensor Circuit Intermittent DTC P0717 Input Speed Sensor Circuit Low Input DTC P0719 Brake Switch Circuit Low Input DTC P0724 Brake Switch Circuit High Input DTC P0730 Incorrect Gear Ratio DTC P0741 TCC System Stuck Off DTC P0742 TCC System Stuck On DTC P0748 Pressure Control Solenoid Circuit Electrical DTC P0751 1-2 Shift Solenoid Valve Performance DTC P0753 1-2 Shift Solenoid Circuit Electrical DTC P0756 2-3 Shift Solenoid Valve Performance DTC P0758 2-3 Shift Solenoid Circuit Electrical DTC P1810 TFP Valve Position Switch Circuit DTC P1860 TCC PWM Solenoid Circuit Electrical DTC P1870 Transmission Component Slipping DTC P1875 4WD Low Switch Circuit Electrical Automatic Transmission - 4L60E (that are not listed with 4L80E) DTC P0740 TCC Enable Solenoid Circuit Electrical DTC P0785 2-3 Shift Solenoid Circuit Electrical Transfer Case DTC B2725 ATC Mode Switch Circuit Malfunction DTC C0300 Rear Speed Sensor Malfunction DTC C0305 Front Speed Sensor Malfunction DTC C0308 Motor A/B Circuit Low DTC C0309 Motor A/B Circuit High DTC C0310 Motor A/B Circuit Open DTC c0315 Motor Ground Circuit Open DTC C0323 T-Case Lock Circuit Low DTC C0324 T-Case Lock Circuit High DTC C0327 Encoder Circuit Malfunction DTC C0367 Front Axle Control Circuit High DTC C0374 General System Malfunction DTC C0376 Front/Rear Shaft Speed Mismatch DTC C0387 Unable to Perform Shift DTC C0550 ECU Malfunction DTC C0611 VIN Information Error Body Control System DTC B1000 ECU Malfunction DTC B1397 Device Voltage Reference Out #1 CKT Low DTC B1398 Device Voltage Reference Out #f CKT High DTC B 1477 Retained Accessory Power Circuit Low DTC B1478 Retained Accessory Power Circuit High DTC B1480 Battery Rundown Protection Circuit Malf DTC B2527 Front Fog Lamp Circuit Low DTC B2577 Headlamp Control Circuit Low DTC B2585 Parklamp Control Circuit Malfunction DTC B2613 Pass Compartment Dimming #1 Circuit High DTC B2617 Pass Compartment Dimming #2 Circuit Low DTC B2618 Pass Compartment Dimming #2 Circuit High DTC B2647 Ambient Light Sensor Circuit Low DTC B2648 Ambient Light Sensor Circuit High DTC B2722 Trans Preference Switch Circuit Low 4L60-E and 4L80-E Transmission DTC B2752 Horn Relay Coil Circuit Low DTC B2947 Security System Sensor Power CKT Low DTC B2948 Security System Sensor Power CKT High DTC B2957 Security System Sensor Data Circuit Low DTC B2958 Security System Sensor Data Circuit High DTC B2960 Sec Sys Sensor Data Incorrect but Valid DTC B2961 Key In Ignition Circuit Malfunction DTC B2973 LF Door Key Switch Circuit Low DTC B3031 Security System Controller in Learn Mode DTC B3033 Security System Indicates Tamper DTC B3102 Keyless Entry Data Link Circuit Low DTC B3137 All Door Lock Circuit Low DTC B3138 All Door Lock Circuit High DTC B3147 RF Unlock Switch Circuit Low DTC B3148 RF Unlock Switch Circuit High DTC COOOO Vehicle Speed Information Circuit Malfunction (W/RTD) or (W/0 RTD) DTC C0472 Steering Handwheel Speed Sensor Signal V Low DTC C0473 Steering Handwheel Speed Sensor Signal V High DTC C0495 EVO Tracking Error (W/RTD) or (W/0 RTD) DTC C0498 Steering Assist Control Actuator Feed Circuit Low DTC C0499 Steering Assist Control Solenoid Feed Circuit High DTC C0503 Steering Assist Control Solenoid Return Circuit Low DTC C0504 Steering Assist Control Solenoid Return Circuit High HVAC System DTC B0159 Outside Air Temperature Sensor Circuit Range/Performance I DTC B0164 Passenger Compartment Temperature Sensor #1 (Single Sensor or LH) Circuit Range/Performance DTC B0174 Output Air Temperature Sensor #1 (Upper; Single or LH) Circuit Range/Performance I DTC B0179 Output Air Temperature Sensor #2 (Lower; Single or LH) Circuit Range/Performance I DTC B0184 Solar Load Sensor #1 CKT Range DTC B0229 Air Flow Control #7 (Recirc) Feedback Circuit Range/Performance I DTC B0248 Mode Door Inoperative Error DTC B0268 Air Flow Control #7 (Recirc) Circuit Malfunction DTC B0408 Temperature Control #1 (Main/Front) Circuit Malfunction DTC B0414 Temperature Control #1 (Main/Front) Feedback Circuit Range/Performance DTC B0429 Air Mix Door #3 Range Error DTC B0434 Temperature Control #3 Rear Feedback Circuit Range DTC B1000 ECU Malfunction DTC B1020 Auxiliary ECU Malfunction DTC B3531 Air Flow Control #10 Rear Circuit Malfunction DTC B3579 Output Air Temperature Sensor #6 Circuit Range/Performance DTC B3584 Output Air Temperature Sensor #7 Circuit Range/Performance DTC B3761 Air Flow Control #3 (Blend Defog/Floor) Feedback Circuit Range/Performance DTC B3764 Airflow Control #4 Mode Feedback Circuit Malfunction DTC U1500 Communication (Front to Rear) State of Health Instrument Panel, Gauges DTC B1367 IPC Ignition 0 Circuit Low DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage in Engine Controls - 4.3L or 4.8L, 5.3L, 6.0L DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage in Engine Controls - 4.3L or 4.8L, 5.3L, 6.0L DTC P0461 Fuel Level Sensor Performance in Engine Controls - 4.3L or 4.8L, 5.3L, 6.0L DTC P0462 Fuel Level Sensor Circuit Low Voltage in Engine Controls - 4.3L or 4.8L, 5.3L, 6.0L DTC P0463 Fuel Level Sensor Circuit High Voltage in Engine Controls - 4.3L or 4.8L, 5.3L, 6.0L DTC P0500 Vehicle Speed Sensor (VSS) Circuit in Engine Controls - 4.3L or 4.8L, 5.3L, 6.0L DTC P0608 Vehicle Speed Output Circuit in Engine Controls - 4.8L, 5.3L, 6.0L DTC P0650 Malfunction Indicator Lamp (MIL) ControlCircuit in Engine Controls - 4.8L, 5.3L, 6.0L DTC P0654 Engine Speed Output Circuit in Engine Controls - 4.8L, 5.3L, 6.0L BXXXX ATC DTCs Refer to A Diagnostic System Check in Transfer Case - NVG 246 CXXXX ATC DTCs Refer to A Diagnostic System Check in Transfer Case - NVG 246 BXXXX BCM DTCs Refer to A Diagnostic System Check - Body Control System in Body Control Systems BXXXX SDM DTCs Refer to A Diagnostic System Check - SIR in SIR CXXXX EBCM DTCs Refer to A Diagnostic System Check in Antilock Brake Systems CXXXX RTD DTCs Refer to Real Time damping Module in Suspension PXXXX Other PCM DTCs Refer to A Powertrain On Board Diagnostic (OBD) System Check in Engine Controls - 4.3L, or 4.8L, 5.3L, 6.0L U1XXX Refer to Scan Tool Does Not Communicate with Class 2 Device in Data Link Communications Cellular Communication OnStar DTC B1000 ECU Malfunction DTC B1004 Keep Alive Memory (KAM) Reset DTC B1009 EEPROM Checksum Error DTC B2462 GPS Signal Error DTC B2476 Cellular Phone Select Service Switch Malfunction DTC U1300 Class 2 Data Link Low DTC U1301 Class 2 Data Link High DTC U1500 Inter-Device Dedicated Bus Malfunction Lighting Systems DTC B2527 Front Fog Lamp Circuit Low DTC B2577 Headlamp Control Circuit Low DTC B2585 Parklamp Control Circuit Malfunction DTC B2613 Pass Compartment Dimming #1 Circuit High DTC B2617 Pass Compartment Dimming #2 Circuit Low DTC B2618 Pass Compartment Dimming #2 Circuit High DTC B2642 Delayed Exterior Lighting Ctrl CKT Low DTC B2643 Delayed Exterior Lighting Ctrl CKT High DTC B2647 Ambient Light Sensor Circuit Low DTC B2648 Ambient Light Sensor Circuit High ABS DTC C0221-C0227 Wheel Speed Sensor Circuit Malfunction DTC C0229 Drop Out of Front Wheel Speed Signals DTC C0235 Rear Wheel Speed Signal Circuit Open DTC C0236 Rear Wheel Speed Signal Circuit Missing DTC C0237 Rear Wheel Speed Signal Erratic DTC C0238 Wheel Speed Mismatch DTC C0241-C0254 EBCM Control Valve Circuit DTC C0265 or C0266 EBCM Relay Circuit DTC C0267 or C0268 Pump Motor Circuit Open/Shorted DTC C0269 or C0274 Excessive Dump/Isolation Time DTC C0271-CQ273, C0284 EBCM Malfunction DTC C0279 Powertrain Configuration Not Valid DTC C0281 Brake Switch Circuit DTC C0283 Traction Switch Shorted to Ground DTC C0287 Delivered Torque Signal Malfunction DTC C0292 Lost communication with Engine Control System DTC C0297 Powertrain Configuration Data Not Received DTC C0298 Powertrain Control Malfunction Real Time Damping (RTD) DTC COOOO Vehicle Speed Information Circuit Malfunction (W/RTD) DTC C0550 ECU Malfunction DTC C0551 Option Configuration Error DTC C0575 Left Front Actuator Circuit Malfunction DTC C0580 Right Front Actuator Circuit Malfunction DTC C0585 Left Rear Actuator Circuit Malfunction DTC C0590 Right Rear Actuator Circuit Malfunction DTC C0615 Left Front Position Sensor Malfunction DTC C0620 Right Front Position Sensor Malfunction DTC C0625 Left Rear Position Sensor Malfunction DTC C0630 Right Rear Position Sensor Malfunction DTC C0655 Level Control Compressor Circuit Malfunction DTC C0660 Level Control Exhaust Valve Circuit Malfunction DTC C0665 Chassis Pitch Signal Circuit DTC C0690 Damper Control Relay Circuit Malfunction DTC C0711 Level Control Air Pressure Sensor Circuit Malfunction DTC C0870 Device Voltage Reference Output # 1 Circuit Malfunction SIR Diagnostic Trouble Code List DTC B0016 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low DTC B0017 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Open DTC B0018 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range DTC B0022 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low DTC B0024 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range DTC B0026 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open DTC B0028 RF/Passenger Side Deployment Loop Resistance Low DTC B0029 RF/Passenger Side Deployment Loop Open DTC B0030 RF/Passenger Side Deployment Loop Short to Ground/Voltage Out of Range DTC B0035 ADS Closed/Shorted to Ground DTC B0036 ADS Open/Missing/Shorted to Battery DTC B0040 LF/Driver Side Deployment Loop Resistance Low DTC B0041 LF/Driver Side Deployment Loop Open DTC B0045 LF Side Deploy Loop Short to Ground/Voltage Out of Range DTC B0051 Deployment Commanded DTC B0053 Deployment Commanded with Loop Malfunctions Present DTC B0077 LF/Driver SIS Malfunction DTC B0078 RF/Passenger SIS Malfunction DTC B0079 Incorrect LF/Driver SIS Installed DTC B0080 Discard LF/Driver SIS DTC B0081 Incorrect RF/Passenger SIS Installed DTC B0082 Discard RF/Passenger SIS DTC B0090 Active Switch Voltage Out of Range DTC B0091 Active Switch: Wrong State DTC B1000 ECU Malfunction DTC B1001 Option Configuration Error DTC U1000 and DTC U1255 Class 2 Communication Malfunction DTC U1001 - U1254 Loss of XXX Communications DTC U1300 Class 2 Data Link Low DTC U1301 Class 2 Data Link High Variable Effort Steering DTC COOOO Vehicle Speed Information Circuit Malfunction (W/RTD) or (W/0 RTD) DTC C0470 Steering Position and Rate of Change Sensor Circuit No. 1 Malfunction DTC C0472 Steering Handwheel Speed Sensor Signal V Low DTC C0473 Steering Handwheel Speed Sensor Signal V High DTC C0495 EVO Tracking Error (W/RTD) or (W/0 RTD) DTC C0496 Steering Assist Control Actuator Feed Circuit Malfunction DTC C0498 Steering Assist Control Actuator Feed Circuit Low DTC C0499 Steering Assist Control Solenoid Feed Circuit High DTC C0501 Steering Assist Control Actuator Return Circuit Malfunction DTC C0503 Steering Assist Control Solenoid Return Circuit Low DTC C0504 Steering Assist Control Solenoid Return Circuit High DTC C0506 Steering Position and Rate of Change Sensor Circuit No. 2 Malfunction 3wbdriver 05-22-2005, 11:13 AM DUDE!!!! Thanks. It's in a Word doc in my Silverado folder now! BlenderWizard 05-22-2005, 12:36 PM Maybe someone can make this a sticky? Automotive Network, Inc., Copyright ©2012
