Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 05-21-2005, 07:43 PM   #1
winsett
winsett's Avatar
winsett Normal reputation
Shuddering Start - Smell Gas
Hi all....Below is a thread I posted in the 'blazer' forums, but one of the guys in there told me I might have better luck getting help with my 5.7L FULL SIZE BLAZER (1994) :
STUTTER START - SMELL GAS
Heres the truck:
1994 Full-Size Blazer 4x4
5.7L 350 TBI
Automatic Trans 144,000kms
Symptoms:
Upon starting truck (easy), engine trembles/shudders for a few seconds before settling into a steady rhythm. I notice a strong smell of raw fuel immediately which disappears after a few moments.
I will however, smell fuel again if I rev up the engine a few times while parked.
One should be aware that this is not the first time that I've encountered fuel delivery problems.
Almost one year ago, I replaced my fuel pump, fuel sending unit, fuel filter, O2 sensor, plugs, rotor, and alternator.
The fuel pump and sending unit were replaced due to a complete lack of starting.
The rest of the replacements came because I experienced a hesitation when accellerating quickly. Sometimes the truck would even lurch forward and almost stall during one of these hesitations.
Thanks to the tips from this forum, this hesitation problem was solved by a tightening of the distributor cap (seems I must have not tightened it after replacing the rotor) as well as resetting the timing with a timing gun. Things were running fine after all this until now.
The fuel problem now seems only to be present at start-up, although sometimes when i let Pedal meet Metal, i again notice a slight hesitation before the truck drops into passing gear.
I'm hoping there is a reletively easy solution to this new problem and I trust that someone out there reading this knows what i am dealing with.
After reading some of the replies from Blazee and BlazerLT, I look forward to hearing their thoughts on this one.
Thanks for your time
Nathaniel W. Coe, AScT.
Forest Engineer
Canada
CHECK OUT MY RIG HERE
http://members.cardomain.com/winsett
winsett is offline   Reply With Quote
Old 05-22-2005, 10:05 PM   #2
mbumgua
mbumgua's Avatar
mbumgua Normal reputation
Injectors are leaking and flooding manifold when you turn on the key and fuel pump pressures up--Check by turning on key to on position and watching the tips of the injectors for drops of gas dripping off. Repaceing injector(s) that are leaking will fix this. Good Luck!!
mbumgua is offline   Reply With Quote
Old 05-22-2005, 10:07 PM   #3
mbumgua
mbumgua's Avatar
Re: Shuddering Start - Smell Gas
Uh--Replacing
Old 05-25-2005, 05:06 AM   #4
winsett
winsett's Avatar
Hi...thanks for the tips...I'm going to have a look at that this weekend then.
Should only be two injectors on the throttle body right?
Forest Engineer
Canada
Old 05-25-2005, 10:29 AM   #5
mbumgua
mbumgua's Avatar
Right-only two and often only one is bad.
Bookmarks
Google
Web AF
