Originally Posted by toomule
passenger door will not unlock from outside, must reach over from drivers seat helpto manually unlatch door from the inside, it has electric locks. HELP
Can you hear the electric motor?
If not, it is not working. If it makes noise, then remove door panel to see if clip is displaced. On my left side, the plastic flipper had broken at 63K miles. You will need a phillips screw driver and a door panel tool. Be careful not to break the door panel clips. Also a dentist tool and small screwdriver are handy for the small screw covers.
