Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 05-19-2005, 05:59 PM   #1
Lundy015
Lundy015 Normal reputation
1996 Chevy S-10 4.3L
I have a 96' s-10 which i've gotten trouble codes for: P0102-mass air flow sensor, P0340-camshaft position sensor and P1441-evap system flow during non-purge. I haven't found anywhere or anyone who can tell me how to narrow down the list of problems and without just starting to replace parts, I'd like to figure out which components are the problem. The mass air sensor and the cam sensor are the two i'm most concerned about. Can anybody tell me if there is anyway to test either the mass air flow sensor or cam position sensor. When starting the truck it tends to want to stall if you don't feather the gas, and sometimes stalls anyway (several times in a row before staying running). After it has started and is idling, there are surges where it'll rev up and then settle back down. Nothing really seems to help or hurt the condition of the idling. Any help would be appreciated, thanks.
Andrew.
Lundy015 is offline   Reply With Quote
Old 05-20-2005, 05:41 AM   #2
jackass#1
jackass#1's Avatar
jackass#1 Normal reputation
Send a message via Yahoo to jackass#1
Re: 1996 Chevy S-10 4.3L
have you tried a tune up? timing? vacuum leaks?
jackass#1 is offline   Reply With Quote
Old 05-21-2005, 03:18 PM   #3
OverBoardProject
Banned
OverBoardProject Normal reputation
Re: Re: 1996 Chevy S-10 4.3L
These few things are always the first things to try with any engine problems, and will cure probably 90% of them.
OverBoardProject is offline   Reply With Quote
Old 05-21-2005, 03:58 PM   #4
blazee
I'm gonna punch yo momma.
blazee's Avatar
blazee +50blazee +50
P0102- Gently clean the MAF. Use brake cleaner because it doesn't leave any residue. Be careful not to damage the sensor.
P0340- The camshaft position sensor is used solely for gathering misfire information. It does not have any effect on performance.
After cleaning the MAF, disconnect the battery for 10 minutes to clear the codes. If the P1441 comes back replace the purge solenoid it should be no more than $20
If problems persist, check for vacuum leaks. Timing cannot be adjusted on 96 and up 4.3s
When was the last time you did a tune-up?
Plugs
Wires
Cap
Rotor
Air Filter
Fuel Filter
PCV valve
Like this post? Hate it?
<----- Click the and tell me what you think.
blazee is offline   Reply With Quote
Bookmarks
Google
Web AF
